Problem setting up Dreamweaver Win7
Apr 7, 2013 3:51 AM
My previous xp machine for classic asp sites, died and I now have a new machine where I have installed windows 7 with IIs6. I still am using CS3 although have cs6 installed on a php machine working OK.
I am having some problems getting Dreamweaver cs3 running correctly.
I had one site on DW running OK lets say Site1 which was running I think OK.
I decided to load another site, Site2
When I did this I had an error message
"this may cause some operations such as synchronization, to work incorrectly"
Site 1 is positioned at D:/Mywebsites/Site1
Site 2 is positioned at D:/Mywebsites/Site2
After getting the error message I deleted the Site2, problem to be investigated after I had finished work on Site1
I then tried to continue with site1 but now cannot get site 1 to open.
When I open Site1/index.htm I get an error message
Module    IIS Web Core
Notification    MapRequestHandler
Handler    StaticFile
Error Code    0x80070002
Requested URL    http://localhost:80/index.htm
Physical Path    C:\inetpub\wwwroot\index.htm
Logon Method    Anonymous
Logon User    Anonymous
It seems to me
Should be http://localhost:80/site1/index.htm
Physical Path    :\inetpub\wwwroot\index.htm
Should be     D:\inetpub\wwwroot\Site1\index.htm
If I attempt to create a new site in Local info with say Site3 I select D:/Mywebsites/Site3 But the Local root folder entry is D:/Mywebsites/ the Site3 does not automatically appear.
I am wondering how I check where is Local host
At the moment I am using D:/inetpub/wwwroot
Many thanks
John Hardy
    Apr 7, 2013 5:13 AM   in reply to johnhardy10
    This alert is typically thrown when one site definition is nested inside another one, e.g.,
    Site1 = D:/Mywebsites/Site1
    Site2 = D:/Mywebsites/Site1/Site2
    Are you sure you didn't have such a structure?
    The rest of your messages are a bit confusing. A file named "index.html" can not contain any VBScript or ASP calls and therefore wouldn't need the participation of IIS at all. It's just a plain-jane HTML file. Nevertheless, how do you have the local testing server for this site defined? What are the contents of all of the fields?
    Let's take another tack - when you use Explorer, where do you see this index.html file located on the D: drive? How have you defined the local root folder in the site definition (i.e., what is the path that you have specified)?
    Apr 7, 2013 6:02 AM   in reply to johnhardy10
    Let's see the details of the site definition for this site please (both local site and testing server)? Can you provide the contents of each field in the definition, please?
