Table Centering
Apr 7, 2013 5:12 PM
How to I center the table? I put in this line into the table area
<table style="margin: auto;"
However the table leans towards the right. If I can get the table to fall evenly below the navigation bar that would help.
The lines in the table header can those divider lines be selectively removed? Thanks
___________________
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<title>Library Page Ten</title>
<!--[if lt IE 9]>
<script src="http://html5shiv.googlecode.com/svn/trunk/html5.js"></script>
<![endif]-->
<style>
body {
    width: 720px;
    margin: 0 auto;
    background-image: url(../../images/backgrounds/fade_bl_BigBaba_Stamps.png);
    background-repeat: repeat;
nav {
width: 720px;
margin:0 auto;
overflow: hidden; /*to control floats*/
nav ul { margin: 0; padding:0 }
nav li {
margin: 0;
padding: 0;
list-style: none;
float: left;
font-size: 14px;
font-variant: small-caps;
font-weight:bold;
nav li a {
margin: 0;
display: block;
text-decoration: none;
color: #000;
width: 120px;
line-height: 2em;
text-align: center;
/**gradients for various browsers**/
background: rgb(232,240,175); /* Old browsers */
background: -moz-linear-gradient(left, rgba(232,240,175,1) 0%, rgba(232,240,175,1) 0%, rgba(162,218,178,1) 53%, rgba(150,218,209,1) 98%); /* FF3.6+ */
background: -webkit-gradient(linear, left top, right top, color-stop(0%, rgba(232,240,175,1)), color-stop(0%, rgba(232,240,175,1)), color-stop(53%, rgba(162,218,178,1)), color-stop(98%, rgba(150,218,209,1))); /* Chrome,Safari4+ */
background: -webkit-linear-gradient(left, rgba(232,240,175,1) 0%, rgba(232,240,175,1) 0%, rgba(162,218,178,1) 53%, rgba(150,218,209,1) 98%); /* Chrome10+,Safari5.1+ */
background: -o-linear-gradient(left, rgba(232,240,175,1) 0%, rgba(232,240,175,1) 0%, rgba(162,218,178,1) 53%, rgba(150,218,209,1) 98%); /* Opera 11.10+ */
background: -ms-linear-gradient(left, rgba(232,240,175,1) 0%, rgba(232,240,175,1) 0%, rgba(162,218,178,1) 53%, rgba(150,218,209,1) 98%); /* IE10+ */
background: linear-gradient(to right, rgba(232,240,175,1) 0%, rgba(232,240,175,1) 0%, rgba(162,218,178,1) 53%, rgba(150,218,209,1) 98%); /* W3C */
filter: progid:DXImageTransform.Microsoft.gradient( startColorstr='#e8f0af', endColorstr='#96dad1', GradientType=1 ); /* IE6-9 */
Color format: Comments IE9 Supp
nav li a:hover, nav li a:active, nav li a:focus {
background: #E8F0AF;
filter:none;
/**clear floats after nav**/
nav:after {
clear: left;
display: block;
</style>
<script src="/pickle/pickle.js" language="javascript"></script>
<link href="/pickle/skins/default/_stylesheet.css" rel="stylesheet" type="text/css" />
<style type="text/css">
table, th, td {
    border: 1px solid #000000;
    border-collapse: collapse;
    color: #FFFFFF;
    background: #FFFFFF url(../../images/3fade_bl_.jpg);
th {
    color: #FF9933;
    background: #FFFFFF;
tr.altRow td {
th, td {
    vertical-align: top;
    padding: 5px;
    background-color: #FFFFFF;
.rightalign {
    text-align: right;
    color: #000000;
    font: normal 12px/normal Geneva, Arial, Helvetica, sans-serif;
    text-transform: none;
.style4 {color: #000000; font-size: 12px; }
.style5 {color: #333333; font-size: 10px; }
.style6 {color: #0099CC}
.style8 {color: #999933}
</style>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
function MM_preloadImages() { //v3.0
  var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
    var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
    if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
</script>
</head>
<body>
<header><img src="http://www.meherbabalibrary.com/logos/Logo10.png" alt="logo" height="128" width="720"> </header>
<nav>
<ul class="style13">
<li><a href="../../index.htm">Baba's Home</a></li>
<li><a href="../../kalki.htm">Kalki's Kitchen</a></li>
<li><a href="../../dvdrent.htm">Fana Fillah</a></li>
<li><a href="../../jive.htm">Curator's Jive</a></li>
<li><a href="../../advent.htm">Advent Vault</a></li>
<li><a href="../../babasplash.htm">Baba Splash</a></li>
</ul>
</nav>
<h2> </h2>
<h2> </h2>
<p align="center"><img src="../../images/Summations/s3/archive_lib.png" alt="Lord Prabhu" width="336" height="41"><br>
THIS IS ONLY A WORK AREA A TEMPLATE</p>
<CENTER>
  <h4>Selected Materials from the Library of the Ancient One</h4>
</center>
<div id="container" style="background-color: bgcolor;">
<div align="center" id="1"></div>
<div id="2"></div>
<div id="3"></div>
</div>
<section class="container">
<div class="child descendant">
  <div class="descendant"></div>
</div>
</section>
</div>
</section>
<div style="float:left:background-color:white"></div>
<div id="content">
<table border="1" cellpadding="5" cellspacing="5" bordercolor="#000000" style="margin: auto;">
  <tr>
    <th scope="col">Guest</th>
    <th scope="col"> </th>
    <th scope="col">Reviews Summations</th>
    <th scope="col">Play Audio Media</th>
  </tr>
  <tr>
    <th width="92" scope="col"><h5 class="style4">Allan Saviskas</h5></th>
    <th width="81" scope="col"><img src="../../images/agents/saviskas06.png" alt="Allan" width="68" height="90"></th>
    <th width="202" scope="col"><a href="../../docs/workamerica.htm" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Image7','','../../images/Summations/s5/ann 2mb2.png',1)"><img src="../../images/Summations/s5/ann2mb1.png" name="Image7" width="300" height="32" border="0"></a></th>
    <th width="269" scope="col"><a href="../../media/media_saviskas.html" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Image8','','../../images/Summations/s5/ann 2mb2.png',1)"><img src="../../images/Summations/s5/ann2mb1.png" name="Image8" width="300" height="32" border="0"></a></th>
  </tr>
  <tr>
    <td> </td>
    <td> </td>
    <td> </td>
    <td> </td>
  </tr>
  <tr>
    <td> </td>
    <td> </td>
    <td> </td>
    <td> </td>
  </tr>
  <tr>
    <td> </td>
    <td> </td>
    <td> </td>
    <td> </td>
  </tr>
  <tr>
    <td> </td>
    <td> </td>
    <td> </td>
    <td> </td>
  </tr>
  <tr>
    <td> </td>
    <td> </td>
    <td> </td>
    <td> </td>
  </tr>
  <tr>
    <td> </td>
    <td> </td>
    <td> </td>
    <td> </td>
  </tr>
  <tr>
    <td> </td>
    <td> </td>
    <td> </td>
    <td> </td>
  </tr>
  <tr>
    <td> </td>
    <td> </td>
    <td> </td>
    <td> </td>
  </tr>
  <tr>
    <td> </td>
    <td> </td>
    <td> </td>
    <td> </td>
  </tr>
  <tr>
    <td> </td>
    <td> </td>
    <td> </td>
    <td> </td>
  </tr>
</table>
<br>
<br>
<p> </p>
<h2 class="style19">Work Sheet</h2>
<p class="style19">Additional Assests Forthcoming</p>
<h1 class="style19"><a href="list_g_lib_eight.html"><img src="../../images/Summations/s6/lib8.png" alt="eight" width="300" height="32"></a><br>
  <a href="list_g_lib_one.html"><img src="../../images/Summations/s6/lib0.png" alt="Home" width="300" height="32"></a></h1>
<dl>
  <dd> </dd>
  </dl>
<p> </p>
<p class="style6"> </p>
<p> </p>
</div>
<div id="Commentary">
  <h2><span class="style18">Link</span>: <br>
    Ezad </h2>
</div>
</body>
</html>
    Apr 7, 2013 5:33 PM   in reply to Timber%%
    Must have a width for auto margins to work.
