Site Definitions CS4 v. CS6
Apr 7, 2013 5:42 PM
Tags: #site #cs6 #definition
I just switched to DW CS6 from CS4. When I defined a Site in CS4, it created an actual folder with my site name that I could see on my hard drive, and my various website files would be in there. CS6 isn't doing that-- although it shows a folder icon that is visible inside of Dreamweaver. I look for it outside of Dreamweaver, and it's not there. This spooks me a little bit. Is this how it works now, or am I doing something wrong? Thanks!
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Apr 7, 2013 8:38 PM   in reply to parker lambert
    Can you verify that you're trying to create a folder within 'Local Site Definition' and not 'Remote Server'? And double, triple-check the path you're providing within DW and verify you're seeing the exact path on your computer's Finder/ Explorer as well.
    Apr 8, 2013 4:40 AM   in reply to parker lambert
    CS4 and CS6 work exactly the same with regard to defining a local site.
    Apr 8, 2013 6:23 AM   in reply to MurraySummers
    Go to Site > Manage Sites > Click the site you are working on > Edit > Click the Advanced tab > Click Local Info
    The path to the folder on your HD will be in the Local Root Folder box
    Apr 8, 2013 3:05 PM   in reply to parker lambert
    Did you Export Site Definition Settings (.ste) files from CS4 and then Import them into CS6?
    Nancy O.
    Apr 9, 2013 5:36 AM   in reply to parker lambert
    The .ste file is wherever you decided to save it. When you export sites from Dreamweaver, the Export Site dialog box lets you choose where to save the site definitions.
    Just FYI, .ste files don't exist unless you export the site definitions yourself. Dreamweaver stores site definitions in the Windows Registry or in a Site Prefs file within the Library/Application Support folder on Mac OS X.
