new2oop
Easiest way to share an XML file online?
Apr 7, 2013 9:52 PM
I have the need to have an XML file syncronised across two computers in two locations. The updates need to be fast (not quite live game fast but close). I don't want to setup a SocketServer just to do this. What's the simplest/easiest way to do this. I had planned to use the Adobe Colaborative Service but that's not available anymore and is probably overkill anyway. Any suggestions?
    Apr 7, 2013 10:23 PM   in reply to new2oop
    If you had a web-hosting service you could put it on your server and display it in a web browser directly:
    "http://myserver.domainextension/myXMLfile.xml"
    as an example.  Please don't click on that link as I don't think it is a real link.  I just made it up to show you what you would type in your web address bar.
    Apr 7, 2013 10:27 PM   in reply to new2oop
    Note, I mentioned the above solution because it is not guaranteed that if you also need to view the XML on a mobile device that it would support Flash Player/Flex Framework unless you deployed a mobile Adobe AIR app for that device-type.  If you're just going to use the 2 computers then you can look into ActionScript 3.0 for XML classes.  One class that comes to mind or one method is XMLList
    Apr 7, 2013 10:35 PM   in reply to new2oop
    I am still not that familiar with Flex so I don't know if it provides RSS.  If it does, then GREAT that would be your answer.
    Have a look at this site:
    http://www.petefreitag.com/item/465.cfm
    It talks about how to create an RSS feed which is what I think would be a great solution for you.
    Apr 7, 2013 10:45 PM   in reply to new2oop
    Also check out this article on stackoverflow:
    http://stackoverflow.com/questions/8406643/actionscript-3-0-rss-feed
    Apr 7, 2013 10:56 PM   in reply to new2oop
    I just saw this article and found that RSS is somewhat slow, but it does notify you of changes.
    http://techcrunch.com/2009/07/09/speeding-up-rss/
    Maybe there's something in the article to explain how to make it work faster than 2 minute intervals.
