Glumdelklitch
I have a boxload of 35 mm negatives begging to be scanned, enhanced and printed
Apr 8, 2013 1:45 PM
Is it possible to scan a 35 mm black-and-white negative (yes, I know it can be done) then use Printshop Elements 11 to virtually develop, enhance, and print to photo paper?  I've a boxload of negatives that are begging to be scanned, catalogued and managed. But what good does it do me if I cannot print them?  Any advice or point toward a source would be greatly appreciated.
Glumdelklitch
    Apr 8, 2013 2:47 PM   in reply to Glumdelklitch
    Glumdelklitch,
    I purchased a stand-alone 35mm film to digital converter for this task. I have Wolverine F2D. With this you scan to a camera card, then upload to your computer. It works well. If you check at Amazon, there are available several units from which to select.
    An alternative is to have a commercial lab do the scanning. Here is one such company:
    http://www.digmypics.com/scanning/filmscanningservice.asp
    Good luck.
    Apr 8, 2013 3:20 PM   in reply to Glumdelklitch
    You can if your scanner has a TMA adapter to scan negatives.
    I'm doing that now on my HP scanner.
    Apr 9, 2013 1:27 AM   in reply to Glumdelklitch
    For your scanner you don't need to look for software. If it can scan slides all you will need is the part that can hold you b&w negatives. Scanning process should be the same as for slides.
    Apr 9, 2013 5:24 AM   in reply to Glumdelklitch
    You're welcome. Glad to help.
