Detecting if a button is clicked
Apr 8, 2013 8:00 PM
Tags: #action #actionscript #as3.0 #movieclip #cs6 #actionscript_3
I am trying to make it so if you click the 5 buttons on my main page frame it will advance you to another frame.  The problem I am having is that the buttons that you click take you away from the main page frame.  So say the main page frame is on frame 1.  buttons 1-5 take you t frames 2-6 (within the main movie frame).  I would like to be able to send the user to page 7 once the 5 buttons are clicked, but I am running into problems with detecting if the button was clicked.  Here is my code with "main" being the movieclip that everything else is inside.
var clickCount:int = 0;
var clipArray:Array = [main.btn1_mc, main.btn2_mc, main.btn3_mc, main.btn4_mc, main.btn5_mc];
for (var i:int = 0; i < clipArray.length; i++) {
    clipArray[i].buttonMode = true;
    clipArray[i].addEventListener(MouseEvent.CLICK, clickHandler);
    clipArray[i].isClicked = false;
    function clickHandler(event:MouseEvent):void {
        switch (event.currentTarget) {
            case main.btn1_mc :
                trace("btn1");
                 break;
            case main.btn2_mc :
                trace("btn2");
                break;
            case main.btn3_mc :
                trace("btn3");
                break;
            case main.btn4_mc :
                trace("btn4");
                break;
            case main.btn5_mc :
                trace("btn5");
                break;
         clickCount++;
         trace(clickCount);
    if(event.currentTarget.isClicked == false){
     event.currentTarget.isClicked = true;
    if(clickCount == clipArray.length){
        trace("All buttons have been clicked");
stop();
any help is appreciated as always.  Thanks
    Apr 8, 2013 11:21 PM   in reply to EverestJ
    Flash doesn`t have "pages". Are you refering to scenes? Show a screenshot of the timeline of your main MovieClip.
    Apr 9, 2013 7:42 AM   in reply to EverestJ
    You can use a second array that contains the buttons that were clicked.
    // initialize
    var buttonsClicked:Array = [];
    // look if the button was collected as clicked
    if (buttonsClicked.indexOf(event.currentTarget) == -1){
         // if not found in array add it
         buttonsClicked.push(event.currentTarget);
    // check if all buttons were clicked
    if (buttonsClicked.length == clipArray.length){
         // all buttons were clicked, let's party
         // or go frame 7 or whatever
         // clear the clicked array again for next turn...
         buttonsClicked = [];
    Apr 9, 2013 7:24 AM   in reply to EverestJ
    I know this sounds confusing and is hard to explain.
    Agreed. This why it would be helpful to put a screenshot of the timeline that shows: all 5 buttons, the stage, if you have actionscript on the timeline a n example how you use it.
    Apr 9, 2013 8:16 AM   in reply to EverestJ
    I can`t see any pictures. Make sure you use jpg/png for compression.
    Apr 10, 2013 1:29 AM   in reply to EverestJ
    make a var on the highest level (root) of your fla:
    var clickcounter:int = 0;
    and a function
    function getClicks():Boolean{
        if(clickcounter>=5){
          return true;
       else{
       return false;
    then inside of every MouseEvent.CLICK-handler of your various buttons add these lines:
    MovieClip(root).clickcounter ++;
    if(MovieClip(root).getClicks()){
       MovieClip(root).main.gotoAndStop(7);
    else{
        //put here the stuff you want to be executed regularly
    Apr 10, 2013 1:16 PM   in reply to EverestJ
    add the following line on the highest level of your fla:
    var clickOrigins:Array = [];
    function checkArray(_target:String,_arr:Array):Boolean{
         if(_arr.indexOf(_target)==-1){
             _arr.push(_target);
            return true;
         else{
           trace("you already clicked that");
           return false;
    and change the addition to your clickHandler to
    //event has to have the same syntax as the argument of your ClickHandler, so if you have written function clickHandler(evt:MouseEvent)...event must be called evt
    if ((MovieClip(root).checkArray(MovieClip(root).clickOrigins, event.currentTarget.name)))
        MovieClip(root).clickcounter++;
    if (MovieClip(root).getClicks())
       //empty the array if you must use it again:
       //MovieClip(root).clickOrigins = [];
    else
    Apr 16, 2013 11:57 PM   in reply to EverestJ
    You don`t show where or how you use a videoplayer in your project or a Timer
