Can exif data be changed in photoshop
Apr 9, 2013 5:35 AM
I am engaged in a nasty lawsuit and now I have a question. So I hope you can help me further.I have a question about adobe Photoshop CS2.
I have added in the annex 2 pictures of properties of a photo. The photo is on 1-10-2010. All the exif data from the camera stand in it too (see CANON EOS 350 d still camera data). Now my question, if you the picture edited in Adobe Photoshop CS2 can then also the date of recording of the photo? I.e. this date change? Continue then the exif data exist, or disappear than the camera data if one adjusts this date in Adobe Photoshop and you only see the "updated" date taken. I have always understood, that if one changes, the date of recording the exif camera data disappear from the picture. In this case, the exposure time, the camaramodel etc.. I understand that you have a create date (exif) original (recorded)
to illustrate the RAW data of the photo:
<exif:DateTimeOriginal>2010-10-01T11:39:18</exif:DateTimeOriginal>
<exif:DateTimeDigitized>2010-10-01T11:39:18</exif:DateTimeDigitized>
and a create date and modify date (date of operation) in photoshop.
To illustrate the RAW data from the same photo:
<xmp:ModifyDate>2010-11-30T20:09:55+01:00</xmp:ModifyDate>
<xmp:CreateDate>2010-10-02T20:29:54+02:00</xmp:CreateDate>
<xmp:MetadataDate>2010-11-30T20:09:55+01:00</xmp:MetadataDate>
<xmp:CreatorTool>Adobe Photoshop CS2 Windows</xmp:CreatorTool>
In this case are the exif data for the original date of recording of the camera and are the xmp data for the dates of editing in Photoshop?
Can anyone confirm this, or is it different story. In advance, thank you very much for the effort, I would very much benefit from
    Apr 9, 2013 6:26 AM   in reply to corrieleushuis
    Using ExifTool you can change anything you like...
    http://www.sno.phy.queensu.ca/~phil/exiftool/
    So nothing is safe.
    Apr 9, 2013 7:10 AM   in reply to corrieleushuis
    You need to be careful of the Date Taken field, and how it is reported.  In Bridge and Photoshop (not sure in other Adobe products) you can change it in the IPTC field but not the Exif field.  But like Paul says you can find a tool to change that field also.
    Apr 9, 2013 7:19 AM   in reply to corrieleushuis
    In Adobe there are 3 dates.  Date Created (set by camera or scanner when imag made), Date File Created (date file originally imported, or file name changed), and Date File modified (edited).  If you do not use special edit tools the Date Created will remain the same.
    Apr 9, 2013 10:24 AM   in reply to corrieleushuis
    Yes they can be changed using Photoshop or Bridge, but you need to use a script to make the changes.
