brewsen
Multi-Frame Averaging Filter
Apr 9, 2013 7:29 AM
Tags: #after_effects_api #multiple_input_frames
I have a filter which requires a history of frames to compute the result (sort of like averaging). I've implemented it using C++ and now I would like to use Adobe Premiere as a frontend. Is this possible? As far as I can tell, filters must be single frame in, single frame out. Is it possible to implement a more stateful filter?
    Apr 9, 2013 7:33 AM   in reply to brewsen
    [moved to the Premiere Pro SDK forum]
    Apr 9, 2013 10:21 AM   in reply to Jeff Bellune
    Yes, what you're asking to do is possible - for example a motion stabilization plugin needs pre and post frames too.
    I suggest you turn it into a AfterFX plugin so that it works with AE and PPro.
    Use the AfterFX SDK to do that:
    http://www.adobe.com/devnet/aftereffects.html
    good luck,
    Edward.
    PS: hattip to Jeff for moving to SDK Forum.
    Apr 24, 2013 12:06 PM   in reply to Rallymax-forum
    Hi brewsen,
    In particular, in the AE SDK, the Checkout sample project demonstrates using input frames from different times to render the output frame.  It also works in Premiere Pro.
    Regards,
    Zac
    Jun 11, 2013 12:23 PM   in reply to brewsen
    Hi there- I'm looking for exacly what you are working on! I'd love to know if and when you have it for Premiere Pro [CS6], and if you are willing to share for a donation.
    Cheers
    PS I'd need a minimum of a 6 frame compounding.
    Jun 11, 2013 2:05 PM   in reply to john_collins
    Grimm.Johnny, what about the Echo filter?  This will combine frames according to the parameters you specify, including Number of Echos (which you can set to 5, for 6 frames of input) and set your Echo operator.
