Detect Sort
Apr 9, 2013 1:57 PM
Is it possible to detect an exisitng sort of a dataProvider (ArrayCollection)?
    Apr 15, 2013 6:45 AM   in reply to Zolotoj
    You could capture a sort on a DataGrid using sortChange and set a variable based on that change.
  • rtalton
    Oct 28, 2008
    Apr 15, 2013 9:05 AM   in reply to Zolotoj
    Hi Zolotoj,
    Within some method you have, you can get the DataProvider's sort like this:
    var currentSort:ISort = this.acMyDataProvider.sort
    Then you can easily examine the SortField's "name" property like this:
    var theSortFieldName:String = currentSort.fields[0].name
    where--
    "acMyDataProvider" is an ArrayCollection,
    "fields" is an Array of SortField,
    "name" is the name of the field used to sort the Collection.
    If more than one SortField is contained in the "fields" collection (like a multiple-field sort), you can loop through them to get the name of each SortField.
    Each SortField object contains all the information and options about the sort, like descending, numeric, compareFunction.
    If it helps anyone else, I often use the following technique to capture the current sort, re-sort on a different field, search for something using the new sort, then revert back to the original sort by doing this:
    EXAMPLE
    //store the current sort, whatever it may be
    var currentSort:ISort = this.acMyDataProvider.sort;
    //change to another sort:
    var newSort:Sort = new Sort();
    newSort.fields = [new SortField('EmployeeName', false, false)];
    acMyDataProvider.sort = newSort;
    acMyDataProvider.refresh();
    //search for a record using the new sort:
    var searchObj:Object = {EmployeeName:'Johnny'};
    var cursor:IViewCursor = this.acMyDataProvider.createCursor();
    if(cursor.findFirst(searchObj)) {
         trace('found');
         //do something with the record
         var employee:Object = cursor.bookmark;
         employee.ID = 95;
         employee.HireDate = new Date();
    //revert back to the old sort, whatever it was:
    this.acMyDataProvider.sort = currentSort;
    In this case I don't need to know the name of the field(s) being sorted on; I just want to restore whatever sort the user has done (like in a DataGrid) after I search for something using a different sort.
    This should give you an idea on the different ways you can use sorting within a Collection.
    HTH
