Horizontal Spry Menu Width Browser Problem
Apr 9, 2013 10:21 PM
I am working in Dreamweaver CS5.5 (mac). I inserted a horizontal spry menu bar within a 900px container. I have six "tabs" going across. When I preview it in Safari, it looks fine. But when I view it in Firefox, it pushes the last tab on to the next line on the left side (aligned with the first tab above). The individual tabs are set to 9.4em and the width of the spry horizontal menu bar itself is set to 900px.
But when I change the width of the spry menu bar from px to em (in both the "box" and "positioning"), it finally fits all on one line in Firefox, however the last tab is slight outside the right edge of the container.
Any ideas how to fix it?
    Apr 9, 2013 10:42 PM   in reply to ZenDao
    Hi ZenDao,
    Could you post  your CSS code here for the experts to help you better?
    Preran
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Apr 9, 2013 10:55 PM   in reply to ZenDao
    Margin & Padding can kill you sometimes!
    Put your files on a webserver and give us a link so we can troubleshoot.
    On a sidenote, Spry has been deprecated and will no longer be officially supported or developed by Adobe: http://blogs.adobe.com/dreamweaver/2012/08/update-on-adobe-spry-framew ork-availability.html
    Apr 10, 2013 3:01 PM   in reply to ZenDao
    Are you a Cloud member?  Cloud comes with Business Catalyst hosting.
    http://forums.adobe.com/docs/DOC-2152
    Nancy O.
    Apr 10, 2013 10:43 PM   in reply to ZenDao
    Try adding
    ul.MenuBarHorizontal li {width: 16.66666%;}
    This is 16.66666 x 6 = 100%
    Apr 25, 2013 10:49 AM   in reply to ZenDao
    Building web page layouts has about as much in common with print design (InDesign and Photoshop) as Elephants have to tea leaves.  Nothing close because print is static & unchanging.  Web pages must be flexible to accommodate various devices/browser settings and display/text sizes which the end user controls.
    DW requires you to understand basic web design theory & coding fundamentals.  If you don't,  you won't have good cross browser results.
    Position:absolute, no.  You don't need positioning.  It's better if you don't use it because it removes content from the normal document flow.  Your copyright info belongs inside your <footer> div; not at the top of your page.
    clip: rect(0px,auto,auto,auto);
    This rule serves no purpose.  I don't know why you included it.
    Re-work your layout without positioning.  Put information in a logical sequence from page top <header> to bottom <footer>.  I highly recommend you use Split View with Live View instead of Design View.  Design View is not 100% reliable.
    Nancy O.
