HollandRisley
Cursors don't change - ButtonMode=true - CS6 Mac Projector
Apr 10, 2013 2:42 AM
Tags: #flash #as3 #projector #cursor #hand #buttonmode #usehandcursor
Hi All,
The problem is that in a Flash Projector created from CS6, the hand / finger cursor does not appear when rolling over buttons, only when in Full Screen mode.
I have created a test FLA here to demonstrate the problem (you have to compile as MAC App then manually go to full screen mode). Is this a known problem?
Thanks in advance.
Simple FLA download here (5.4kb)
The timeline has 1 frame and the stage has a single movieclip buttonMC containing 1 rectangle only. The first frame has the following code. I have also tried adding .mouseChildren = false:
buttonMC.addEventListener(MouseEvent.CLICK, Clicked);
buttonMC.addEventListener(MouseEvent.ROLL_OVER, MouseOver, false, 0, true);
buttonMC.addEventListener(MouseEvent.ROLL_OUT, MouseOut, false, 0, true);
buttonMC.buttonMode = true;
buttonMC.useHandCursor = true;
function Clicked(event:MouseEvent) {
          trace("Clicked");
function MouseOver(event:MouseEvent):void{
          trace("MouseOVer");
function MouseOut(event:MouseEvent):void{
            trace("MouseOut");
  • kglad
    Jul 21, 2002
    Apr 10, 2013 8:46 AM   in reply to HollandRisley
    if you're publishing for 11.3 or better, you could try using fullScreenInteractive instead of fullScreen for the stage displayState.
    Apr 11, 2013 5:44 AM   in reply to HollandRisley
    Make a custom cursor like this one and recreate the standard MacOS handCursor.
  • kglad
    Jul 21, 2002
    Apr 11, 2013 6:53 AM   in reply to HollandRisley
    when you publish a projector file, you add a flash player to your app and you do target particular flash players.  that's why, if you publish a projector file, it's still larger than a few mb.
  • kglad
    Jul 21, 2002
    Apr 11, 2013 7:51 AM   in reply to HollandRisley
    update (help>updates) your flash.  i have 11.3 and 11.4 as fp options for cs6.
    Jun 21, 2013 12:34 PM   in reply to HollandRisley
    Wondering if anyone has figured this out yet? Thanks!
