Bug with title and timeline windows synchronization
Apr 10, 2013 1:06 PM
Premiere CS5.5
1) We write sequence zero point 10:00:00:00
2) Add some video on timeline
3) Create new title
And as result we will not see that video as a background in Title window.
Because Timecode changing of sequence does not affect to Title window.
I think that it is bug.
    Apr 10, 2013 1:31 PM   in reply to Malcev.Z
    It was a little hard to understand your steps and result. But it sounds like you may not have 'show background video' toggled on in the titler, or else it's pointing to a frame in the timecode where your video is not at.
    Apr 10, 2013 1:42 PM   in reply to Malcev.Z
    Do you have the toggle on in the Titler that displays video from the sequence.
    It can be turned Off & On.
    Apr 10, 2013 2:03 PM   in reply to Malcev.Z
    I tested for you ...your steps
    The Titler does open showing the CTI   at  10:00:00:00 in its TC WIndow but the Clip dos not show in the BG .  Toggling On and Off does nothing but...
    Slipping the TC a frame makes the BG from the Sequence Display
    Not sure its a bug  but definitely a "glitch".
    Workaround is easy though and as I never change Start TC it wont affect me anyway.
    YOu could also ...change yourstart TC after you complete your EDIT.
    Apr 10, 2013 2:26 PM   in reply to shooternz
    OK, I see now. It's a bug with a workaround. Thanks.
