ballooning C drive
Apr 10, 2013 6:05 PM
Using premiere cs6.... The 1T   C drive , suddenly  contains  644gb in the Roaming folder,  99% of that being associated with Adobe files, as:  Media Cache": 465g (all cfa), Cache New, Media Cache  etc.  This seems a bit excessive?
Is there any reason not to delete these?  will all the cfa files be restored automatically?
    Apr 10, 2013 6:12 PM   in reply to rmartin215
    PP will rebuild those files when you reopen the project that needs them.  Best to have those on their own drive...
    C: System
    D: Projects
    E: Scratch
    F: Media
    G: Exports
    ...or at least off the C: drive...
    C: System
    D: Projects/Scratch
    E: Media/Exports
    Apr 10, 2013 8:26 PM   in reply to rmartin215
    Drive C space http://forums.adobe.com/thread/1007934?tstart=0
    You don't specify, so the Mac version http://forums.adobe.com/thread/1070067 (is the boot drive on a Mac the C drive?)
    Apr 10, 2013 9:37 PM   in reply to John T Smith
    Macintosh uses names for volumes, not letters.
    Apr 11, 2013 1:14 AM   in reply to rmartin215
    If you go to the Edit Menu, and select Preferences, and the Media tab, you will find two "Browse" buttons.  You should use these to shift your Media cache off your C:\ drive onto another fast drive in your system - ideally not the drive which contains your media files.  Create an Adobe file on the target drive before you start, and navigate to it when you browse.
    You can then safely delete your exiting cache on your system drive, and Premiere will re-create the files it needs in your new location.  It is a good idea to use the "Clean" button on the Media tab at intervals to remove all the files which are no longer required.
