thorit
Elements 11 closes itself
Apr 11, 2013 5:26 AM
PC: Windows 7 Home Premium 64bit SP 1, 8 GB RAM, Intel Core I5.
Windows is fully updated.
No use of Oganizer for pictures.
Hi
I have recently purchased my pc (3 weeks) and started out with installing my Elements 9, but it would only let me edit about 2 - 10 pictures (jpeg) before Elements would close itself.
Thought it might be a case where Elements 9 couldn't run on a 64bit pc, so upgraded to Elements 11.
Now I can edit anywhere from 5 - 25 pictures (jpeg) before Elements will close itself.
Sometimes a Windows dialog window will apear and tell me that Elements stopped working and will be closed, but most of the time Elements simply just closes without any notification.
I can then try to open the picture again in Elements, but Elements will close itself right away. Only thing that helps is to reboot the computer, and then I can edit a few pictures again before the problem repeats itself.
I then tried to set Elements up to run in campability mode with Windows XP SP 3, but that didn't help.
Then I uninstalled Elements and made a reboot, and then reinstall Elements and under installtion choose install as Administrator mode and again choose Windows XP SP 3 compability mode.
But the problem is still here
What can I do to make this issue go away ?
Regards
Thomas Rithmester
Denmark
    Apr 11, 2013 8:52 AM   in reply to thorit
    Find the exact cause of the crash:
    Working with your Operating System’s Tools
    Mylenium
    Apr 11, 2013 2:47 PM   in reply to thorit
    Moving this discussion to the Photoshop Elements forum.
    Apr 11, 2013 10:51 PM   in reply to thorit
    Is it specific to catalog? Try creating a new catalog and see if that crashes. If you are unable to change catalog from within Organizer, launch Organizer keeping 'shift' key pressed.
    ~Andromeda
