PE10:How can I limit  a transition to just part of the video
Apr 11, 2013 8:16 AM
Tags: #transition #matte
I want to limit the page peel transition to affect the portion of the video screen that depicts a screen showing a slide presentation. The slide show does not show up on the video, so I have to overlay the screen with images from the slide show & want the transitions to affects just that part of the screen.
I can’t seem to limit the transition with a matte.
    Apr 11, 2013 9:22 AM   in reply to TRUE_SEEKER
    It's not quite clear what you're asking, True. Are you saying your video frame is divided into a grid and you want your transition to affect only one portion of the grid or a picture-in-picture?
    Apr 11, 2013 9:48 AM   in reply to Steve Grisetti
    Sounds like picture-in-picture to me.
    Apr 11, 2013 4:05 PM   in reply to TRUE_SEEKER
    There is not an easy way to do this.
    The only real way to do this in Premiere Elements is to make a separate project which includes your slide and its transition. Use Publish & Share/Computer/AVI to output this segment. Then import this AVI into your project and use it as your PIP.
    Apr 12, 2013 12:20 PM   in reply to TRUE_SEEKER
    Great news!
    That is sort of like the workflow in PrPro, where one would create a Sequence (think of a mini-Project, in a Project), then edit with the desired Transition, and then Nest that Sequence into a new one, where the PiP would be created from it. In PrE, there are no Sequences, so no Nesting, but you got around that by editing in a Project, then Exporting/Sharing, to then Import into another Project. More than one way to "skin a cat."
    Steve G. always has some great workflow modifications, to get most things to work in PrE. Those suggestions are always greatly appreciated.
