michael.c.fleming
Illustrator CS4 view doesn't match view of same file in Acrobat
Apr 11, 2013 9:27 AM
Tags: #illustrator
We're seeing a pretty strange problem with Illustrator CS4 (Mac and PC). The problem seems to happen ins CS5 and CS6 as well. We have a complex piece of artwork for a foil blister and we use a paragraph of text that has 3 transforms applied to which effectively step and repeat the paragraph of text in a repeat pattern across the artwork. This setup very precisely as it needs to be 100% accurate for print purposes as several units are printed side by side and the repeat runs across the units. Everything is setup correctly in Illustrator and then we re-save as a PDF with 'Preserve Illustrator Editing Capabilities' on.
We genearally save as a PDF 1.6 but we have tried all the combinations now. The file still looks perfect in Illustrator but when the PDF is opened in Acrobat (any version) the step and repeat (transform) on the paragraph of text is now no longer in alignment on onside of the artwork but still OK on one side. No matter what we do we can't fix this problem andit's recreatable each time. Also it's not file specific as we can build a new file and it will also exhibit the problem. We're only talking about a tiny jump here - <0.2mm but this means the artwork is out of spec. Any help is gratefully received!!!!
    Apr 11, 2013 10:17 AM   in reply to michael.c.fleming
    Michael:
    Know this is a dumb question, but are you embedding the fonts? Or, maybe it's a font that can't be embedded due to legal restrictions?
    In your Acrobat preferences, what do you see if you turn off "Use Local Fonts" under Page Display > Rendering?
    What happens if you outline the fonts and then "Save As" a PDF?
    Apr 11, 2013 11:10 AM   in reply to michael.c.fleming
    It may be helpful to provide a sample .ai file, so one can take a look at it.
    Just in case you're free to do that.
