I know this has been asked before but I can't seem to find anything current. I came across some stuff but the links were diead or explanatory images didn't show.
It seems that Report Builder doesn't do crosstabs. I wondered if anyone had come across any kind of workaround. What I would like to show is something like:
Books Circulated
Jan Feb Mar Apr... Year Total
Red Books 100 200 300 400
Blue Books 300 100 200 200
Total 400 300 500 600
Seems like it should be doable. I usually us a crosstab and it is relatively straightforward. Any suggestions in Reprot Builder? Thanks.
A report will accept whatever data-set you provide it.
The trick is to do the crosstab using your database engine. The result-set returned by the database engine can easily be used to create a report.
It is worth noting that Report Builder is for creating fixed layout reports. It is not possible to have a dynamic number of fields generated at run-time. You have to explicitly place each field in the report.
What this means is that your cross-tab query must always return the same number of fields, or at a minimum it needs to return the fields that appear in the report.
If you have more questions feel free to ask.
