ljohnston46
DW Cs6: will my images not show up when previewing in browser
Apr 11, 2013 4:54 PM
Tags: #image #cs6 #dw
DWcs6: will my images not show up when previewing in browser unless my site is connected to a server? currently I am working remotely not connected to the server. I can see my images in live view but not when previewed in browser.
    Apr 11, 2013 5:17 PM   in reply to ljohnston46
    If images don't appear correctly in browsers, it's likely a bad path.  This typically happens when you start working on a project without first Defining a Local Site Folder in DW. Without this first step, DW cannot properly manage assets and links for you.
    Wrong path:
    file:///user/desktop/folder/filename.jpg
    Correct path:
    images/filename.jpg
    Or possibly you used the wrong type of image file.  Images need to be optimized & Saved for Web as .jpg, .png or .gif files.
    Nancy O.
    Apr 11, 2013 5:41 PM   in reply to ljohnston46
    Are these pages saved as .html pages -- not .php or .asp?
    Are you working with clean code?
    Code Validation Tools
    CSS - http://jigsaw.w3.org/css-validator/
    HTML - http://validator.w3.org/
    Can you show us your markup?
    Nancy O.
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Apr 11, 2013 9:41 PM   in reply to ljohnston46
    When you try to preview in browser, what is the URL you're seeing in the address bar of your browser? Is it referring to your local copy (file://) or a remote server copy (http://)?
    Do you have a 'testing server' defined in your site within DW? If so, what is the testing server path you've given there?
    Apr 12, 2013 9:48 AM   in reply to ljohnston46
    The URl in preview is c:/file//
    Did you define a Local Site Folder in DW before you started this project?  Without this critical first step, none of your link paths will be correctly pointing to your site folder.
    Go to Site > New Site and tell DW where to find files on your local hard drive.  See Screenshot.
    Nancy O.
