epubJunkie
DOCTYPE in SVG incompatible with epubcheck 3.0
Apr 11, 2013 4:35 PM
Tags: #svg #epubcheck #doctype
CS6 Illustrator by default inserts a DOCTYPE tag in SVG 1.1 output. This seems to be perfectly legal when looking at the SVG 1.1 spec. Rumor has it that it will no longer be legal in SVG 1.2, whenever that appears.
When epubcheck 3.0 checks an epub 3.0 document and encounters the DOCTYPE tag, it spews a bunch of errors:
java -jar epubcheck-3.0.jar -mode svg -v 3.0 charGlyph.svg
Epubcheck Version 3.0
WARNING: charGlyph.svg/: File is validated as a single file of type svg and version 3.0. Only a subset of the available tests is run.
ERROR: charGlyph.svg/charGlyph.svg: External DTD entities are not allowed. Remove the DOCTYPE.
ERROR: charGlyph.svg/charGlyph.svg(60,31): External entities are not allowed. External entity declaration found: %svg-model.mod
ERROR: charGlyph.svg/charGlyph.svg(65,33): External entities are not allowed. External entity declaration found: %svg-attribs.mod
ERROR: charGlyph.svg/charGlyph.svg(72,33): External entities are not allowed. External entity declaration found: %svg-framework.mod
ERROR: charGlyph.svg/charGlyph.svg(103,33): External entities are not allowed. External entity declaration found: %svg-datatypes.mod
ERROR: charGlyph.svg/charGlyph.svg(197,29): External entities are not allowed. External entity declaration found: %svg-qname.mod
ERROR: charGlyph.svg/charGlyph.svg(865,35): External entities are not allowed. External entity declaration found: %svg-core-attrib.mod
ERROR: charGlyph.svg/charGlyph.svg(923,40): External entities are not allowed. External entity declaration found: %svg-container-attrib.mod
ERROR: charGlyph.svg/charGlyph.svg(968,39): External entities are not allowed. External entity declaration found: %svg-viewport-attrib.mod
ERROR: charGlyph.svg/charGlyph.svg(1018,36): External entities are not allowed. External entity declaration found: %svg-paint-attrib.mod
ERROR: charGlyph.svg/charGlyph.svg(1139,38): External entities are not allowed. External entity declaration found: %svg-opacity-attrib.mod
ERROR: charGlyph.svg/charGlyph.svg(1191,39): External entities are not allowed. External entity declaration found: %svg-graphics-attrib.mod
ERROR: charGlyph.svg/charGlyph.svg(1268,40): External entities are not allowed. External entity declaration found: %svg-docevents-attrib.mod
ERROR: charGlyph.svg/charGlyph.svg(1335,42): External entities are not allowed. External entity declaration found: %svg-graphevents-attrib.mod
ERROR: charGlyph.svg/charGlyph.svg(1423,41): External entities are not allowed. External entity declaration found: %svg-animevents-attrib.mod
ERROR: charGlyph.svg/charGlyph.svg(1480,36): External entities are not allowed. External entity declaration found: %svg-xlink-attrib.mod
ERROR: charGlyph.svg/charGlyph.svg(1568,43): External entities are not allowed. External entity declaration found: %svg-extresources-attrib.mod
ERROR: charGlyph.svg/charGlyph.svg(1612,33): External entities are not allowed. External entity declaration found: %svg-structure.mod
ERROR: charGlyph.svg/charGlyph.svg(1961,35): External entities are not allowed. External entity declaration found: %svg-conditional.mod
ERROR: charGlyph.svg/charGlyph.svg(2102,29): External entities are not allowed. External entity declaration found: %svg-image.mod
ERROR: charGlyph.svg/charGlyph.svg(2203,29): External entities are not allowed. External entity declaration found: %svg-style.mod
ERROR: charGlyph.svg/charGlyph.svg(2292,29): External entities are not allowed. External entity declaration found: %svg-shape.mod
ERROR: charGlyph.svg/charGlyph.svg(2619,28): External entities are not allowed. External entity declaration found: %svg-text.mod
ERROR: charGlyph.svg/charGlyph.svg(3055,30): External entities are not allowed. External entity declaration found: %svg-marker.mod
ERROR: charGlyph.svg/charGlyph.svg(3198,31): External entities are not allowed. External entity declaration found: %svg-profile.mod
ERROR: charGlyph.svg/charGlyph.svg(3279,32): External entities are not allowed. External entity declaration found: %svg-gradient.mod
ERROR: charGlyph.svg/charGlyph.svg(3437,31): External entities are not allowed. External entity declaration found: %svg-pattern.mod
ERROR: charGlyph.svg/charGlyph.svg(3572,28): External entities are not allowed. External entity declaration found: %svg-clip.mod
ERROR: charGlyph.svg/charGlyph.svg(3681,28): External entities are not allowed. External entity declaration found: %svg-mask.mod
ERROR: charGlyph.svg/charGlyph.svg(3822,30): External entities are not allowed. External entity declaration found: %svg-filter.mod
ERROR: charGlyph.svg/charGlyph.svg(4637,30): External entities are not allowed. External entity declaration found: %svg-cursor.mod
ERROR: charGlyph.svg/charGlyph.svg(4723,33): External entities are not allowed. External entity declaration found: %svg-hyperlink.mod
ERROR: charGlyph.svg/charGlyph.svg(4854,28): External entities are not allowed. External entity declaration found: %svg-view.mod
ERROR: charGlyph.svg/charGlyph.svg(4926,30): External entities are not allowed. External entity declaration found: %svg-script.mod
ERROR: charGlyph.svg/charGlyph.svg(4997,33): External entities are not allowed. External entity declaration found: %svg-animation.mod
ERROR: charGlyph.svg/charGlyph.svg(5283,28): External entities are not allowed. External entity declaration found: %svg-font.mod
ERROR: charGlyph.svg/charGlyph.svg(5669,37): External entities are not allowed. External entity declaration found: %svg-extensibility.mod
Does Adobe regard this as an epubcheck bug? Has Adobe discussed this with the epubcheck people? At least one other opensource svg converter doesn't output a doctype.
TIA...
