cmerger
Photos do not upload since I upgraded to the latest software version
Apr 11, 2013 11:13 PM
I have upgraded both my Mac, iPad and iPhone to the latest software version.
Now my photos are no longer uploaded to the AdobeRevel site and consequently not downloade back to my other devices.
Is the service working?Everything just worked fine before I did the upgrade.
Help needed.
    Apr 12, 2013 3:19 PM   in reply to cmerger
    Hello,
    The service is working correctly as Revel should be working better as before. Are you trying to upload at the same time on multiple devices? Can you log in to Adoberevel.com to see if your photos are showing up there and also try to upload a few sample pictures to see if they can upload
    Scott
    Apr 12, 2013 4:11 PM   in reply to Scott V
    I am not having trouble uploading. I want to delete some, as I have over 5,000. Every time I click on more than one photo it goes into a slide show.
    thanks.
    Apr 12, 2013 11:38 PM   in reply to mary sch 2010
    Mary-
    Your issue is different from the one above, in which case it is better to start a new thread.
    Iphone:
    Open the library you want to delete a photo from.
    Click on the trash can icon at the bottom of the  screen
    Select photos to be deleted
    Click on remove at the bottom right of the screen
    Confirm Deletion
    Browser:
    Click on  select photos in the menu
    Select the photos to deleted by clicking on them. You will see a check appear on those selected.
    Click on the trash can icon at the top of the  screen
    Confirm deletion
    Mac:
    Select files to deete. If you want more than one, hold the command key down to select additional files
    click the delete key on your keyboard
    See this FAQ for more  file  info:
    FAQ: File Basics: How do I Upload, Download, Share, and Delete files in Revel?
    Pattie
    Apr 13, 2013 5:32 PM   in reply to cmerger
    Claude-
    Since it appears you are in France, here is something for you to check in your iPad:
    In your ipad device's Settings > General > International    please ensure you have a region set here and see if that helps your issue. Let us know.
    One more thing, when you look in your library, do you have a green dot or a red dot?
    Pattie
    Apr 14, 2013 2:03 PM   in reply to cmerger
    What about the dot by the library name on your ipad? Is it green or red?
    Pattie
    Apr 14, 2013 2:37 PM   in reply to cmerger
    Claude
    Check the status view in Revel by tapping the LED at the top. If you see a photo that appears stuck in Uploading Changes, and you are certain you can import that photo again, delete the photo and then re-import it. If you unsure about having the original image available for re-import, don't delete it -- but let me know, and we can try patching your account from our end.
    There was a bug in the previous version of Revel, where favoriting a photo while offline could cause the photo to get stuck in Uploading Changes. The cause of the issue is fixed in the current app release (version 1.10), but updating to the current release won't clear the problem if was already present. You'll have to delete the stuck image and re-import like I mentioned, or we will need to work it on our end.
    Pattie
    Apr 15, 2013 9:23 AM   in reply to cmerger
    I will look into your specific account situation  and get back to you with more suggestions
    Pattie
  • Charlie.D
    Jun 16, 2009
    Apr 17, 2013 9:54 AM   in reply to cmerger
    Hi Claude
    We think we fixed this on our server.  Can you try again and let us know if the problem is resolved, or if it continues?
    Apr 18, 2013 3:00 PM   in reply to cmerger
    Claude-
    We are very happy that this is working for you now. Enjoy Revel.
    Pattie
