Aliasing of Static Images
Apr 12, 2013 4:33 AM
Tags: #aliasing #static_image
I filmed a presentation where most of the content was slides scanned from old books and catalogs. To improve viewability I took the presenter's powerpoints, wrote them to .pdf and then individually scaled them in Photoshop. I then went into to each slide and saved the individual images as separate images (he had them all in .jpeg so I am stuck with that). It didn't look bad inside premiere but once I export it to an .mp4 the old images with lots of lines tend to crawl and its quite distracting. You did a little test video on the first slide:
https://vimeo.com/63505591
Anyone know the best way to stop this before I jump into editing. I don't have access to the original documents--just the scans that were embedded in the slides. Also since there are 80 slides I am hoping the suggestion won't be something like "rescale all 80+ slides."
Thanks for any suggestions.
    Apr 12, 2013 5:18 AM   in reply to John Ellenberger
    You could try adding a blur filter to the slides.
    Apr 12, 2013 6:45 AM   in reply to John Ellenberger
    In the Premiere Effects tab there is a Blur and Sharpen folder. Try testing out Fast Blur appled to a silde then export to MP4.
    Apr 12, 2013 6:48 AM   in reply to John Ellenberger
    Try adding, in Premiere, a Gaussian Blur found under Video Effects/Blur & Sharpen, adjust the amount until the pattering is reduced but the photo is still sharp enough. When you have found a good setting for one photo copy and paste attributes to the other stills.
    Apr 12, 2013 9:23 AM   in reply to John Ellenberger
    This is not right.  You shouldn't need any effects for this to look good.
    What format is the video?  What are your sequence and export settings?
    Apr 12, 2013 9:51 AM   in reply to John Ellenberger
    What is the resolution fo the original images? Since your sequence is SD, maybe the images are very high resolution thus creating the problem?
    Apr 12, 2013 10:07 AM   in reply to John Ellenberger
    Nice fix. Congras!
    Apr 12, 2013 10:21 AM   in reply to John Ellenberger
    The sequence setting is: 720 x 480  29.97 fps
    To output I was just using one of the Vimeo presets:  640x480, 25 fps, progressive vbr, 2 pass 2 Mbps
    Get the frame rates to match.
