Predatorhackz
How to get Hotspots to stay in the same place in Responsive Design?
Apr 12, 2013 8:35 AM
Tags: #design #html #links #css #layout #html5 #cs6 #dw #fluid #responsive
Hello Adobe Community,
                                      This is my first post on the forum and it's a question. I have a nav bar image with seperate buttons inside, which i want to be linked to the corrosponding pages. However whenever i create a hotspot, the page resizes and the hotspots are moved! I understand why this is happening (Due to the page size changing and the hotspots staying where they are), however i was just wondering if there was a way around this problem. I will attatch the site below however note that this site is not complete and is just for test purposes.
http://www.julialange.co.nf
Thank you for reading and i hope you can help, this is driving me crazy!
My Dreamweaver Version is CS6
I have the full CS6 suite if that helps.
The Navigation bar on the site above is what i am refering to.
Thank you in advance for any help.
    Apr 12, 2013 10:02 AM   in reply to Predatorhackz
    Owing to the fixed nature of hotspot coordinates, they do not resize with the image map.  As such, scalable image maps must be avoided in responsive or % based layouts.
    For  a lot of semantic reasons, it's better to use CSS styled lists for menus.
    Example:
    http://alt-web.com/FluidGrid/Fluid2.html
    Nancy O.
    Apr 19, 2013 4:19 PM   in reply to Nancy O.
    Hi, I am actually posting my version of the question, rather than any answer...
    I understand by Nancy's comments that there is an alternative and better way to manage "traditional" menus.
    What if, instead, my menu is displayed "in circle" around an area, and I want to display different information (mainly text) inside the circle, and sometimes aside it, depending on what menu element I hover on?
    I did it in flash (see http://www.csegno.com.ar/fla/cSegno%20flash%20page.html) and I am basically trying to replicate it in a fluid layout fashion (js, css, etc..) , to make it available to tablets/smartphones as well.
    Thanks a lot!
    Cristiano
    Apr 20, 2013 10:36 AM   in reply to cSegno
    Hi cSegno,
    Unfortunately the easy method of using css exclusions to do this, is only supported semi-completely in some browsers behind a preference setting.
    The other method would be to use the html5 canvas element and javascript. The canvas element is supported by all modern mobile devices.
    PZ
    Apr 20, 2013 4:14 PM   in reply to cSegno
