"Duplicate File Found"
Apr 12, 2013 10:04 AM
Tags: #file #found" #"duplicate
Not sure what is going on. "Duplicate File Found" at disk build.
The first time I encoded with AME at too high a bit rate. I re-encoded at lower bit rate and deleting the original files. I then renamed the re-encoded files to the original filenames used in the project. I don't see any duplicate files anywhere.
Then I tried deleting all of the projects asset files and cleaned the media database. I then re-imported all file assets and rebuilt the DVD menues from scratch. I still get this message "Duplicate File Found".
I have run out of options other than wiping out the enitre project and starting from the very begining.
    Apr 12, 2013 12:23 PM   in reply to GSC inc
    So we are all on the same page, by DVD content,  you mean the "DVD-ROM Content" in the build tab?
    Certainly there were various red flags, which you were trying to address:
    "reencoded, deleted, renamed" and "copied a backup copy" are concepts that Encore is not fond of.
    But how could you get a duplicate file, even in the ROM content?
    Apr 12, 2013 1:06 PM   in reply to GSC inc
    Encore should not even care what is going into the "DVD-ROM Conten" folder.
    I agree.
    Apr 27, 2013 4:02 AM   in reply to Stan Jones
    I am having a related problem. (Mac OS 10.8.3)
    My DVD-ROM Content is causing the DVD image build and DVD Master build to show "0 Objects" in the resulting disc image .iso and the physical DVD. There is not even a Video TS folder "visible".
    However, the physical Video DVD will launch the DVD Player and play as expected when inserted into a computer. The DVD-ROM Content is of course not visible in the Finder as mentioned before.
    I have authored a second DVD, also with DVD-ROM Content (Adobe PDF documents) and there doesn't seem to be a problem...
    ... I think that I have found the source of the Problem:
    File names for the DVD-ROM Content must adhere to a standard naming convention.
    -NO SPECIAL CHARACTERS-. (Blank spacing between words doesn't seem to cause this problem)
    Apr 27, 2013 7:21 AM   in reply to marq5.1
    Hmm... I have several saved message links about "odd" file names causing problems... but those are about the direct files, not ROM files... very interesting
    http://forums.adobe.com/thread/588273
    http://forums.adobe.com/thread/666558
    http://forums.adobe.com/thread/665641
