div tag question
Apr 15, 2013 5:01 AM
Hello Dreamweavers.
Im trying to have 2 div tags one into another,and Im following a tutorial
but the im getting a different result from the instructors.
also here is the link of the vid tutorial,Id like to know if its a good way to go on about with this method,
http://www.youtube.com/watch?v=x23e4YRADQI
thank you.
    Apr 15, 2013 5:22 AM   in reply to inquestflash
    Since you are not including the CSS styles from the tutorial, this is an educated guess. Based on the images, the tutorial appears to be centering each div on the page and specifying both positioning and specific heights and widths for each div. Go back and compare the tutorial's stylesheed (indicated by line 6 of the tutorial code that starts <link href="style.css" . . . />) with your CSS code. In your version, you've only defined background color and height. Your code is giving you the correct result: each  divdisplaying the full width of your viewport with the "small" div being immediately shown after the "large" one.
    Chris
    Apr 15, 2013 5:52 AM   in reply to inquestflash
    thank you.
    Yes, the method the tutorial teaches is good. Setting height is not good BUT used in the tutorial it was just to show you the <divs> as rectangles with coloured backgrounds which makes the tutorial easier to follow.
    Apr 15, 2013 5:55 AM   in reply to osgood_
    As osgood says, the technique is fine (apart from giving a div a fixed height). The reason yours doesn't work is because you have not nested the second div inside the first one.
    You have this:
    <div id="big"></div>
    <div id="small"></div>
    It should be this:
    <div id="big">
    </div>
