PAL subtitles to NTSC ?
Apr 15, 2013 1:34 PM
Tags: #convert #pal #ntsc #subtitles #timecode
I have done a PAL movie and have a subtitle file.
All the subs line up.
Now I have done a NTSC version of the same movie.
The subtitles time code entry point will be different I am assuming.
Is there a PAL to NTSC subtitle timecode converter out there?
    Apr 15, 2013 7:11 PM   in reply to Mr Bansaw
    If it's a 4% speed conversion, then you will need to retime each one.  My subtile company charges extra, and will not convert it any possbile way.
    If its a same time conversion, you might be able to cut and paste them in a final cut pro sequence. (confused by this?)  It's a long story, but possible.
    Apr 16, 2013 5:26 AM   in reply to FilmLover99
    Encore will import a subtitle file. I would use Excel to convert the codes and export a new file. I see numerous references to convertors, but few if any were just converting timecodes themselves. I'd explore that.
    Apr 17, 2013 9:02 AM   in reply to Mr Bansaw
    I hadn't thought about it that way. I wonder why they are off?
    So a subtitle that starts at fps 29.97 00;00;02;00 should still start at 25fps 00;00;02;00. So why doesn't it?
    Apr 17, 2013 1:03 PM   in reply to Mr Bansaw
    PAL is non-drop timecode, right?
    Apr 17, 2013 4:42 PM   in reply to Stan Jones
    It is important that your script files correctly specify the timecode for your project. The timecode you use depends on the television standard of the project:
    NTSC
    NTSC projects use drop-frame timecode, which separates the numbers with semicolons, as in hh;mm;ss;ff (hours; minutes; seconds; frames).
    PAL
    PAL projects use timecode that separates the numbers with colons, as in hh:mm:ss:ff (hours: minutes: seconds: frames).
    Apr 18, 2013 8:31 AM   in reply to Mr Bansaw
    Excellent!
