LingWang3
how to save PDF file with color profile
Apr 15, 2013 3:10 PM
Tags: #pdf #color_profiles
I tried following action script code to save PDF file with color profile attached:
                   var saveOps: PDFSaveOptions  = new PDFSaveOptions();
                   saveOps.colorConversionID  = ColorConversion.COLORCONVERSIONTODEST;
           saveOps.colorDestinationID = ColorDestination.COLORDESTINATIONWORKINGCMYK;
           saveOps.colorProfileID = ColorProfile.INCLUDEDESTPROFILE;
           doc.saveAs(pdfFile, saveOps);
But got following errors: error an Illustrator error occurred: 1346458189 ('PARM').
What is the correct way to save PDF file with color profile?
Thanks!
Ling
    Apr 23, 2013 2:46 AM   in reply to LingWang3
    Hi Ling
    I'm new here so I didn't try it out, but with JavaScript for Adobe I solved a similar Problem with making a correct pdf-Export setting (with the correct icc-Profile included) and applying it to the pdf-export by name.
    I guess it works in AS too. Mybe it helps.
    richard
    Apr 25, 2013 2:41 AM   in reply to LingWang3
    Hi Ling
    if you make a pdf-ExportPreset were you can define your icc-Profile and everything else for the export you can use this preset with
    saveOps.pDFPreset("nameOfYourPreset");
    if you use saveOps.colorProfileID the color management must be turned ON - did you do that?
    My JavaScript was written for InDesign - it seems that you have more possibilities in InDesign.
    richard
    Apr 25, 2013 3:43 AM   in reply to richardhauck
    The understatement of the year!
    Every time I have to script something in Illy, I feel like I have my hands tied behind my back...
