Web hmtl gallery customization.
Apr 15, 2013 7:10 PM
Tags: #web_gallery #image_size #html_gallery #thumbnail_size
Hi, All.
I am working with the Web module in Lightroom 4 (now 4.4) to create an online gallery with photos. I like the layout of the HMTL default template and would like to use. The only problem I found is that I can't seem to find a way to change the size of the thumbnail images and the enlarged photo that appears once the viewer clicks on the thumbnail.
Is there a way to do this ?
TIA.
    Apr 16, 2013 1:19 AM   in reply to Joe_Caldwell
    I don't think you can change  the thumbnail sizes, only how many per page, but you can change the enlarged photo size using the "Image Pages/ Size " slider value.
    Apr 16, 2013 3:21 AM   in reply to Joe_Caldwell
    You can use this modified version if you wish.
  • John Blaustein
    Aug 11, 2002
    Apr 16, 2013 4:19 PM   in reply to john beardsworth
    John,
    Your version is a terrific improvement over the default one.  Thanks so much for sharing it.
    John
    Apr 17, 2013 12:04 PM   in reply to Joe_Caldwell
    I assume you unzipped the file, Joe, and restarted LR.
    Apr 17, 2013 12:30 PM   in reply to Joe_Caldwell
    That all sounds right (I've tested in 4.4 and 5 Beta). Do you not see it listed in the Layout Style panel? It should display as Lightroom HTML Gallery - JB mod.
    John
    Apr 17, 2013 2:59 PM   in reply to Joe_Caldwell
    It would not be shown in the templates - only in the Layout Style panel (top of right panel).
  • John Blaustein
    Aug 11, 2002
    Apr 17, 2013 3:20 PM   in reply to Joe_Caldwell
    Joe,
    Are you sure you are putting the correct folder into your LR Web Galleries folder?  When you extract John's ZIP file, you will have a folder called default_html_modified.lrwebengine.  Inside that folder is another folder with the same name.  It's that one that you want to copy -- the one with all of the other files and folders inside it.  See my attached image.
    And, as John said, be sure you are looking at the panel on the upper right of the LR window.
    Hope this helps.
    John
    EDIT:  GLAD YOU FOUND IT!
    Message was edited by: John Blaustein
  • John Blaustein
    Aug 11, 2002
    Apr 18, 2013 8:29 AM   in reply to Joe_Caldwell
    Joe,
    Check this out:
    http://forums.adobe.com/thread/1194889
    John has updated the gallery as of yesterday.
    John
  • John Blaustein
    Aug 11, 2002
    Apr 19, 2013 7:42 PM   in reply to Joe_Caldwell
    Hi Joe,
    You are welcome.
    As far as simple, straightforward HTML galleries go, John's gallery is perfect in my book.
    Juicebox is nice because it will work on non-Flash mobile devices (like iPad, iPhone).  I have not used it.
    I use SlideShowPro for LR for my own website, and have found it to be very elegant and easy to work with.  Take a look here:
    http://slideshowpro.net/products/slideshowpro_player/#ssplr
    You might also want to check out:
    http://theturninggate.net/
    John
