How do I keep tool settings from changing?
Apr 15, 2013 6:50 PM
I will change settings on a tool, use it for awhile, then change to a different tool.  When I return to the first tool, the settings have reverted to the defaults.  How do I keep them from changing while I am using a different tool?
Thanks!
    Apr 15, 2013 6:52 PM   in reply to CornerGuy
    That makes no sense, unless you are mistakenly trying to change tools via tool presets - which always load the settings associated with that preset.
    Otherwise each tool can only remember the last used settings.
    Apr 15, 2013 8:33 PM   in reply to CornerGuy
    Again, that can't happen if you just switch using the tools in the toolbar.
    But could if you select tool presets (which include specific tool settings).
  • Noel Carboni
    Dec 23, 2006
    Apr 15, 2013 8:36 PM   in reply to CornerGuy
    What Chris is wondering is:  How, EXACTLY, are you changing tools?
    Most just click on the tool they want to use in the Tools panel.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Apr 23, 2013 8:23 AM   in reply to CornerGuy
    Thanks for the detail.  I can reproduce exactly what you're describing with Photoshop CS6 13.1.2.
    What you want is reasonable.  Perhaps Adobe will fix it in the next release.
    -Noel
