alexlake
ColdFusion 10 + jTDS to SQLAnywhere timeout
Apr 16, 2013 6:14 AM
Tags: #sqlanywhere #jtds
Got a new installation of CF10 running on 64 bit Ubuntu 12.04LTS.
Trying to connect to Sybase ASA (AKA SQLAnywhere) v8 using jTDS.
I put jtds-1.3.0.jar and jcifs_1.3.17 into a directory that's in the CF Java Classpath - and that seems good, CF seems to be able to find that right enough.
But when I configure a Datasource:
JDBC URL: jdbc:jtds:sybase://1.2.3.4:2638/mydatabase
Driverclass: net.sourceforge.jtds.jdbc.Driver
Username: xxx
Password: yyy
It doesn't work - I get a very rapid timeout error message:
Connection verification failed for data source: dmcc-jtds
java.sql.SQLException: Timed out trying to establish connection
The root cause was that: java.sql.SQLException: Timed out trying to establish connection
I can connect to the same database using the SQLAnywhere native commandline tools (so not a firewall issue).
I saw that someone else reported this problem on StackOverflow but if any solution was found, they didn't put it up!
Help!
BTW, this is in the CF internal logfile:
"Error","ajp-bio-8012-exec-6","04/16/13","15:09:23",,"Timed out trying to establish connection"
        at coldfusion.server.j2ee.sql.pool.JDBCPool.requestConnection(JDBCPool.j ava:843)
        at coldfusion.server.j2ee.sql.pool.JDBCManager.requestConnection(JDBCMan ager.java:125)
        at coldfusion.server.j2ee.sql.JRunDataSource.getConnection(JRunDataSourc e.java:135)
        at coldfusion.sql.CFDataSource.getConnection(CFDataSource.java:42)
        at coldfusion.sql.Executive.verifyDatasource(Executive.java:492)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl. java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:597)
        at coldfusion.runtime.StructBean.invoke(StructBean.java:508)
        at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2465)
        at cfudflibrary2ecfm1867463752$funcVERIFYDSN.runFunction(E:\cf10_final\c fusion\wwwroot\CFIDE\administrator\datasources\udflibrary.cfm:14)
        at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:472)
        at coldfusion.runtime.UDFMethod$ArgumentCollectionFilter.invoke(UDFMetho d.java:368)
        at coldfusion.filter.FunctionAccessFilter.invoke(FunctionAccessFilter.ja va:55)
        at coldfusion.runtime.UDFMethod.runFilterChain(UDFMethod.java:321)
        at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:518)
        at coldfusion.runtime.CfJspPage._invokeUDF(CfJspPage.java:2624)
        at cfindex2ecfm782328217._factor12(E:\cf10_final\cfusion\wwwroot\CFIDE\a dministrator\datasources\index.cfm:450)
        at cfindex2ecfm782328217._factor17(E:\cf10_final\cfusion\wwwroot\CFIDE\a dministrator\datasources\index.cfm:396)
        at cfindex2ecfm782328217._factor18(E:\cf10_final\cfusion\wwwroot\CFIDE\a dministrator\datasources\index.cfm:168)
        at cfindex2ecfm782328217.runPage(E:\cf10_final\cfusion\wwwroot\CFIDE\adm inistrator\datasources\index.cfm:1)
        at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:244)
        at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:444)
        at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
        at coldfusion.filter.IpFilter.invoke(IpFilter.java:64)
        at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:443 )
        at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.ja va:48)
        at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
        at coldfusion.filter.PathFilter.invoke(PathFilter.java:112)
        at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:94)
        at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePers istenceFilter.java:28)
        at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
        at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
        at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
        at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
        at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:62)
        at coldfusion.CfmServlet.service(CfmServlet.java:204)
        at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:8 9)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Appl icationFilterChain.java:305)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationF ilterChain.java:210)
        at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringS ervletFilter.java:42)
        at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46 )
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Appl icationFilterChain.java:243)
        at coldfusion.filter.ClickjackingProtectionFilter.doFilter(ClickjackingP rotectionFilter.java:75)
    Jul 18, 2013 4:12 PM   in reply to alexlake
    Thanks alexlake to point out the right directory.  In addition to that, I have to add "?charset=iso_1" to the JDBC URL in order to make the connection.
    It looks like- JDBC URL  "jdbc:sybase:Tds:<host>:<port>/<dbname>?charset=iso_1"
