What's Wrong With This Code?
Apr 16, 2013 10:00 AM
I've been trying to get a test automaton plugin to work.  It builds correctly with no errors or warnings yet when I attempt to use it, I get no results.  No errors either.  All its intended to do is Copy > Make New Layer > Paste.  The code is below.  The sample code used was the MakeSelectFill plugin that I modified from the old 6.0 SDK along with using an older copy of Visual C++ that can open the project.  Any help is much appreciated.
#include <stdio.h>//defines sprintf
#include "PIUGet.h"//defines PIUGetInfo, not used in MakeSelectFill
#include "PIDefines.h"//defines __PIMac__, __PIWin__
#include "PIGeneral.h"//defines kPSPhotoshopCaller, kPSDoIt
#include "SPInterf.h"//defines kSPInterfaceCaller, kSPInterfaceAboutSelector,
        //kSPInterfaceStartupSelector,
#include "SPBasic.h"//defines SPBasicSuite
#include "SPAccess.h"//defines kSPAccessCaller, kSPAccessReloadSelector,
        //kSPAccessUnloadSelector, not used in MakeSelectFill
#include "PIActions.h"//defines PSActionDescriptorProcs, PSActionReferenceProcs,
        //PSActionControlProcs
#include "ADMBasic.h"//contains cross-platform alert dialogs, about boxes,
        //file and directory dialogs, string conversions
#include "PIUSuites.h"//defines PIUSuitesAcquire and PIUSuitesRelease
//          Function Prototypes.
DLLExport SPAPI SPErr PluginMain(const char* caller,
        const char* selector,
        const void* data );
//          Globals -- Define global variables for plug-in scope.
SPBasicSuite                              *sSPBasic = NULL;// the Basic Suite
//create pointers to the suites
PSActionDescriptorProcs          *sPSActionDescriptor = NULL;
PSActionReferenceProcs          *sPSActionReference = NULL;
PSActionControlProcs          *sPSActionControl = NULL;
PSActionListProcs                    *sPSActionList = NULL;
ADMBasicSuite                              *sADMBasic = NULL;
_AcquireList MySuites[] =
          kPSActionDescriptorSuite, kPSActionDescriptorSuiteVersion, (void **)&sPSActionDescriptor,
          kPSActionReferenceSuite, kPSActionReferenceSuiteVersion, (void **)&sPSActionReference,
          //note that the previous version of the Control suite is used for compatibility with 5.5
          kPSActionControlSuite, kPSActionControlSuitePrevVersion, (void **)&sPSActionControl,
          kPSActionListSuite, kPSActionListSuiteVersion, (void **)&sPSActionList,
          kADMBasicSuite, kADMBasicSuiteVersion, (void **)&sADMBasic
//          PluginMain
//          All calls to the plug-in module come through this routine.
//          It must be placed first in the resource. To achieve this,
//          most development systems require this be the first routine
//          in the source.
//          The entrypoint will be "pascal void" for Macintosh,
//          "void" for Windows.
DLLExport SPAPI SPErr PluginMain(const char* caller, // who is calling
        const char* selector, // what they want
        const void* data )// the message
          SPErr error = kSPNoError;
          SPMessageData *basicMessage = NULL;
          // all messages contain a SPMessageData*
          basicMessage = (SPMessageData *) data;
          sSPBasic = basicMessage->basic;
          // acquire all the global suite pointers now
          error = PIUSuitesAcquire(sSPBasic,
                                   MySuites,
                                   sizeof (MySuites) / sizeof (_AcquireList));
          if (error) return error;
          // check for SP interface callers
          if (sSPBasic->IsEqual((char*)caller, kSPInterfaceCaller))
                    if (sSPBasic->IsEqual((char*)selector, kSPInterfaceAboutSelector))
          // Photoshop is calling
          if (sSPBasic->IsEqual((char*)caller, kPSPhotoshopCaller))
                    // the one and only message
                    if (sSPBasic->IsEqual((char*)selector, kPSDoIt))
          // clean up, free memory
          PIUSuitesRelease(sSPBasic,
                           MySuites,
          return error;
}/*end PluginMain*/
//          Test Plugin
//          This plugin is used as a test.
//          Its functions are Copy > Make New Layer > Paste
SPErr Copy(void)
     PIActionDescriptor result = NULL;
     error = sPSActionControl->Play(&result, eventCopy, NULL, plugInDialogSilent);
     if (error) goto returnError;
returnError:
     if (result != NULL) sPSActionDescriptor->Free(result);
     return error;
//make new layer here//
SPErr MakeLayer(void)
          PIActionDescriptor descriptor = NULL;
          PIActionReference reference = NULL;
          error = sPSActionDescriptor->Make(&descriptor);
                    // Move this to the top of the routine!
                    error = sPSActionReference->Make(&reference);
                    error = sPSActionReference->PutClass(reference,classLayer);
                    error = sPSActionDescriptor->PutReference(descriptor,keyNull,reference);
                    error = sPSActionControl->Play(&result,eventMake,descriptor,plugInDialogSilen t);
returnError:
                    if (descriptor != NULL) sPSActionDescriptor->Free(descriptor);
                    if (reference != NULL) sPSActionReference->Free(reference);
                    return error;
//end make new layer//
//start paste//
SPErr Paste(void)
error = sPSActionControl->Play(&result,eventPaste,NULL,plugInDialogSilent);
returnError:
return error;
//end paste//
// all windows plug-ins need a DllMain
#ifdef __PIWin__
BOOL APIENTRY DllMain( HANDLE hModule,
                                                          DWORD ul_rearson_for_call,
                                                          LPVOID lpReserved )
          return TRUE;
#endif
    May 16, 2013 10:10 PM   in reply to SuperBeer Dude
    You seem to be missing something inside here. Probably Copy();MakeLayer();Paste();
