Iglota
path inside an Array
Apr 16, 2013 12:18 PM
Tags: #array #listener #object
I was trying to put a 'path ' in an Array
// I Create the Array
var matrizFunc:Array=new Array();
// put What a need inside it
matrizFunc [0] = 'Tela.AreaInterativaLogin.entrar';
//I call the Array element to work with teh Listener
matrizFunc[0].addEventListener(MouseEvent.CLICK,TelaMenuInicial);
It doens't work. Any clue?
tks a lot!
    Apr 16, 2013 12:36 PM   in reply to Iglota
    You say that this string is a path. What do you mean by that? As far as the array is concerned, 'Tela.AreaInterativaLogin.entrar' is a string and doesn't really relate to much of anything.
    What is it that you intend to accomplish? Are you going to display this string on the stage somehow?
    Apr 16, 2013 4:39 PM   in reply to Iglota
    What is "Tela.AreaInterativaLogin.entrar"? You described it as a path earlier. If it is a path, what is it a path to? Is this a path to a movieClip that you want to attach an event listener to?
    Apr 17, 2013 5:41 AM   in reply to Iglota
    OK, If the movieClip "Tela" is at the same level as the code that you are writing, then you just need to remove the quotation marks from this line: matrizFunc [0] = 'Tela.AreaInterativaLogin.entrar';
    That path describes an object in Actionscript and so it is not a string.
