Sync metadata from jpeg to raw
Apr 16, 2013 1:20 PM
Tags: #metadata #geotag #lr4
Hi, I'm using an Eye-fi Pro X2 card in my D5100. At present Eye-Fi haven't been able to resolve the fact that geodata isn't added to the Raw (nef) file so I am shooting in Raw+jpeg. Is there a way to sync the metadata from the jpeg to the nef file within LR4?  Will this be written to the raw file, to a sidecar file or the LR database?
    Apr 16, 2013 1:28 PM   in reply to pfield69
    If you click on the JPG, then ctrl-click on the RAW, and then click on Sync Metadata, this will copy the GPS metadata (and any other metadata you want) to the RAW. You would have to do this one pair of JPG/RAW photos at a time. You might be able to use ExifTool to globally move the metadata.
    This information is written to the Lightroom database by default, which is where Lightroom stores ALL metadata. Optionally, you can also have it written to a sidecar file.
    Apr 16, 2013 2:23 PM   in reply to pfield69
    I am assuming you want sync in bulk.
    If that's correct, then consider a plugin, e.g.
    Syncomatic (dunno if it supports geodata - it supports whatever the Lr sdk supports).
    RawPlusJpeg (definitely supports geodata: it uses exiftool, not Lr sdk).
    RelativeAntics (@now, supports same metadata as syncomatic - both are using the same mechanism: sdk methods).
    Rob
    Apr 18, 2013 2:59 PM   in reply to pfield69
    So, which plugin did you go with, pfield69?
    May 13, 2013 7:50 AM   in reply to pfield69
    1. Select either an individual Raw + Jpeg pair or the pairs taken at the same location
    2. Switch to the Map Module
    3. In the Map Module you should see a Location icon showing the number of files that are tagged
    4. Click on Map/Untagged
    5. Drag and drop the files on to the Location icon to add that tag to the untagged files
