djkarluk
Adobe Drive 4 AAMEE 3.1 Installer Issues
Apr 17, 2013 10:55 AM
Tags: #adobe #cs6 #drive #aamee #aamee3.1 #adobedrive #aamee_3.1 #adobe_drive
I have followed the enterprise deployment advice on the following document for a Windows deployment through SCCM http://help.adobe.com/en_US/AdobeDrive/4.2/Adobe_Drive_Admin_Guide.pdf
However, I am getting stuck and need some help.
When I first ran the MSI file that was created bu AAMEE 3.1 I encountered the following error
WARNING: DW039: Payload {C3BC3DF1-83AB-4808-A672-474E15340D4B} Adobe Drive 4 4.0.0.0 is not installed so should not be there in the deployment file
After reading through the logs I found the entries
C:\Users\username\Desktop\Adobe Drive 4.0\Build\\Setup\runtime\adobe_caps.dll
Caps Library path doesn't exist
Caps Library load Failed or Function Resolving failed
Custom action return code: 65535
There was no "runtime" folder underneath the Setup folder. I looked at the original installer and located the "runtime" folder and copied it to the Setup folder. After this I also saw the following post mention something similar for MACs http://forums.adobe.com/message/5243030#5243030.
I am now seeing this error as the first error in the logs when I run the AAMEE msi file, then it rolls back.
::START TIMER:: [Pre payload :{C3BC3DF1-83AB-4808-A672-474E15340D4B}]
In PrePayloadInstallProc
Adobe Player for Embedding
Adobe Player for Embedding x64
Adobe Drive 4 x64
Microsoft Visual C++ 2005 Redistributable Package (x86)
Microsoft Visual C++ 2008 Redistributable Package (x64)
Microsoft Visual C++ 2008 Redistributable Package (x86)
Microsoft Visual C++ 2010 Redistributable Package (x64)
Microsoft Visual C++ 2010 Redistributable Package (x86)
Adobe Drive 4
AdobeJRE
:: END TIMER :: [Pre payload :{C3BC3DF1-83AB-4808-A672-474E15340D4B}] took 80.5097 milliseconds (0.0805097 seconds)
[    4564] Wed Apr 17 18:35:47 2013 ERROR
DW030: Custom Action for payload {C3BC3DF1-83AB-4808-A672-474E15340D4B} Adobe Drive 4 4.0.0.0 returned error. Failing this payload.
The summary at the end of the log displays:
I have run the Adobe Support Adviser on the log file and I get nspection could not identify any issues.
I have full CS6 Web and Design Premium installed on the computer.
I have tried he same process with Adobe Drive 4.0 and Adobe Drive 4.2 and get the same errors.
I have ran the installation with my domain account that has local administration rights, elevating the installer.
I have ran the installation as the computer local administrator
If I run the non-AAMEE insallation Adobe Drive installs fine, however this is not mass deployable through SCCM to my knowledge.
Can anyone help, I have a deadline of Friday to have Adobe Drive deployed within our environment......
