LaxKings
MPG File Problems
Apr 17, 2013 2:33 PM
Tags: #error #premiere #bug #import #mpg #decompressing
Everytime I try to import my mpg file into Premiere, I get the error saying: "There was an error decompressing audio or video."
The File Opens fine in After Effects. Please Help.
    Apr 17, 2013 2:49 PM   in reply to LaxKings
    Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
    What is a CODEC... a Primer http://forums.adobe.com/thread/546811
    What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
    Report back with the codec details of your file, use the programs below... A screen shot works well to SHOW people what you are doing
    http://forums.adobe.com/thread/592070?tstart=30
    For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
    For Mac http://mediainspector.massanti.com/
    Welcome to the forum.
    What are the full specs., both Audio & Video, in your MPEG files?
  • joe bloe premiere
    Dec 6, 2009
    Apr 17, 2013 3:14 PM   in reply to LaxKings
  • joe bloe premiere
    Dec 6, 2009
    Apr 17, 2013 3:31 PM   in reply to LaxKings
    Can you open that file with Media Encoder?
  • joe bloe premiere
    Dec 6, 2009
    Apr 17, 2013 3:38 PM   in reply to LaxKings
    First, I don't see any particular reason why you
    can't open this file in Premiere.
    But, in the interest of moving ahead with the edit,
    you might consider using Media Encoder to flip it
    to another edit-friendly codec:
    Lagarith Lossless Video Codec
    http://lags.leetcode.net/codec.html
    Ut Video Codec Suite
    http://www.videohelp.com/tools/Ut-Video-Codec-Suite
    Avid Codecs 2.3.7 - DNxHD
    http://avid.force.com/pkb/articles/en_US/download/en423319
  • joe bloe premiere
    Dec 6, 2009
    Apr 17, 2013 5:27 PM   in reply to LaxKings
    Are you on a pc or mac?
    Lagarith & Ut are 'lossless' at the expense of larger files.
    DNxHD is 'virtually lossless', also larger files.
    Pick a codec (I lean to Ut on a pc), download and install;
    then bring your .mpg into Media Encoder and transcode
    the file to that codec and you are off and running.
    note:
    Lagarith is pc only - .avi
    Ut is cross-platform - .avi / .mov
    DNxHD is cross-platform - .mov
    All three codecs are free.
    edit:
    As you transcode your file, be sure to match
    the frame size / aspect ratio / frame rate of the original.
    Apr 17, 2013 4:05 PM   in reply to LaxKings
    >Overall bit rate mode                    : Variable
    As far as I know, PPro does not do well (if at all) with trying to edit a variable bit rate file
    Apr 17, 2013 7:22 PM   in reply to John T Smith
    PP actually does fine with VBR MPEG.
    Here's what I'd check.
    FAQ: Why are some codecs and sequence presets missing from my installation of Premiere Pro?
    Apr 17, 2013 8:14 PM   in reply to Jim Simon
    My mistake http://forums.adobe.com/thread/1110005 I had remembered a message about a variable FRAME rate
    Apr 17, 2013 9:32 PM   in reply to John T Smith
    Yes, that's a no-no.
    Apr 17, 2013 9:49 PM   in reply to John T Smith
    That is what I thought that you were referring to, as well.
