Save for the web jagged fonts nightmare
Apr 17, 2013 2:41 PM
Hi
Can't export anti-aliased smooth fonts using save for the web. The fonts are jagged.
How can save for the web the same smooth quality that I see on the screen?
Using Illustrator CS6 on Mac OS X 10.8.3
Thanks.
    Apr 17, 2013 2:44 PM   in reply to Tom Adobe
    when you save it as a jpeg or png, you are converting it to a raster image but it shouldn't be too noticeable unless you are enlarging it. Can you post some pictures?
    Apr 17, 2013 2:51 PM   in reply to Tom Adobe
    In the Save for Web&Devices dialog box, Set this dropdown to Type
    Apr 17, 2013 3:13 PM   in reply to Tom Adobe
    What happens if you use Export instead of Save for Web&Devices? You can save with a higher ppi instead of the 72 that you will get from Save for Web.
    Apr 17, 2013 7:16 PM   in reply to Tom Adobe
    What is the size of the art and are you enlargening it in the browser using CSS or manually adjusting the size?
    In both cases I am using save for web. In the first instance I am exporting at 100% size, 200% size in the next instance. If you are resizing in CSS/manually, export from Illy at the desired size.
    Mike
