I have been using Captivate since version 4 and this is the first time I have had this problem. The generated PDF (which is the expected file size) displays a blank page with only the TOC button which sits there flashing rapidly. I have tried changing the targeted Flash Player version without any luck. Previews and HTML output is fine and so is the .exe file. I am using Adobe Acrobat 11 on a 64-bit Windows system. This is a fairly small project with about 15 slides and some FLV videos. I have no problems with Distiller with any of my other programs (FrameMaker, LiveCycle, Photoshop etc.). Any settings I can fiddle around with?
Any ideas?
Nadeem
Thanks for the helpful reference!
To anyone else having a similar problem: the solution (while not ideal, since it requires disabling a desired feature) is to uncheck the "Show TOC" box in the TOC settings. To reiterate what was discussed in the forum, the problem apppears to be localised to Acrobat Pro/Reader XI. So far there is no resolution from Adobe.
Nadeem
