adding new text style
Apr 18, 2013 11:58 AM
I have a style that shows in Photoshop, but not Premiere Pro.
Babylonian5 Hollow.  How do I use it in the latter?
    Apr 18, 2013 12:03 PM   in reply to robirdman1
    A style is something specific in both programs  Do you just mean a font?
    I've noticed that PP doesn't necessarily show fonts alphabetically.  Have you scrolled the entire list?
    Apr 18, 2013 1:40 PM   in reply to robirdman1
    I thought I was missing Arial "Black" until I noticed there is a drop down box below the base font name. Maybe that's it.
    Curious.
    If you create a title in PS using one of those fonts, and bring it into PP as a .psd, is it the same font?
    Apr 19, 2013 10:56 AM   in reply to robirdman1
    I am not sure how to just create a title in PS and bring it in.
    1. In PS, go to File>New Image, and then choose one of the Video Presets, that matches your Sequence, and a Transparent Background.
    2. Use the Type Tool to create the Title, as desired.
    3. Save_As PSD, and Import that into the PrPro Project.
    Apr 24, 2013 8:25 PM   in reply to robirdman1
    File>New...
    First line of the dialog is the name.  Second line is for presets.
    Apr 23, 2013 4:24 PM   in reply to robirdman1
    In Photoshop, at New Image, you have a dialog box, that will pop up. One can use the drop-down for the Video Presets. Then, on that same dialog screen, you can choose the Background, and Transparent is what you want.
    Apr 23, 2013 4:30 PM   in reply to Bill Hunt
    Here is a look at the New Image dialog, with the 1920 x 1080 Video Preset chosen, and the Transparent Background in the drop-down:
    Depending on the exact version of PS that you have, the dialog box might look slightly different.
    Hope that helps and good luck,
    Apr 24, 2013 8:26 PM   in reply to robirdman1
    Don't know.  What font is it?
  • joe bloe premiere
    Dec 6, 2009
    Apr 25, 2013 9:15 AM   in reply to robirdman1
    ...why I can't access that font directly in PP.
    Babylonian5 Hollow
    Did you mean: Babylon 5 Hollow?
    Style vs. Font... two different things.
    Mixed terminology has added some confusion to this thread.
  • joe bloe premiere
    Dec 6, 2009
    Apr 25, 2013 12:31 PM   in reply to robirdman1
    As you can see... I installed the font
    and it worked fine in Premiere.
    Are you on pc or mac?
    I am on a pc (CS6.0.3).
    Apr 25, 2013 8:58 PM   in reply to joe bloe premiere
    Worked for me, too.
    Apr 26, 2013 9:53 AM   in reply to robirdman1
    Well, they are for us.  Which means, if we presume no operator error here, the issue is probably a local one.  (Meaning something went glitchy on your system.)
  • joe bloe premiere
    Dec 6, 2009
    Apr 28, 2013 7:50 AM   in reply to robirdman1
    Okie dokie... one more shot at this.
    Based on your mixed use of terminology (Style vs. Font)...
    is it possible you are trying to find the font by
    looking in your 'Title Styles' (circled in red)?
    If so, you need to look in the dropdown menu under Properties
    named 'Font Family' (circled in green).
    Titler Text Styles
    Titler text styles / Create a style
