IslayMalt
Newbie Blu Ray Audio Question
Apr 18, 2013 3:37 PM
Tags: #blu-ray #bluray #dts #dts-hd #dolby_digital
Greetings, Not exactly "new" to Premiere, but left the game before Blu Ray came along.  I am using Premiere Pro 6 to author my first Blu Ray Disc.  I am importing material into Premiere that has DTS-HD 5.1 soundtrack.  After making the appropriate adjustemets to my Segment properties, the imported video lays down just fine.  As I run the video in the Segment Window, I can see all 5.1 channels doing their their thing on the levels meter.  Life is good.
Whe I go to "Make" this Blu Ray disc (using Encore, which is also new since I left NLE), I assume it will burn the content (my movie) with the DTS-HD 5.1 track, BUT will it or can it generate a stereo track as well?  This is important as not every blu ray player can decode DTS-HD signals.  I need this Blu Ray to be able to play in almost any Blu Ray player HOWEVER I want the surround sound track there and used, if the player can decode it.  Make Sense?
My imported clips are HandBrake products from a MKV files.  When I attempt to generate a Handbrake mp4 that contains both a stereo and DST-HD 5.1 track, Premiere only seems to see the stereo track.  Wierd.
I apologize in advance if this is a stupid question, but I'm working a project now and don't really have time to plow through all the basics to get to an essoteric question such as this?
FWIW:  Windows 7 64- Bit fully loaded with Pioneer Blu Ray burner.
Please Help,
Many Thanks,
IslayMalt
    Apr 18, 2013 3:48 PM   in reply to IslayMalt
    Welcome to the forum.
    Please don't double-post.  I deleted your duplicate topic in the Pr forum.
    Jeff
    Apr 18, 2013 3:52 PM   in reply to IslayMalt
    It is indeed an En question.
    The DTS audio stream cannot be muxed into a file with a video stream.  It must remain separate, which is why your .mp4 didn't work.  If you create a separate stereo track and add it to its own audio track in your En timeline, you'll be able to set up the menus to let the audience choose which audio track they want to hear.
    Jeff
    Apr 18, 2013 3:54 PM   in reply to IslayMalt
    Encore passes through the 5.1.  You can't preview it. You must create a  separate file with the stereo. You will have an Encore timeline with the video and two audio tracks, one 5.1 and one stereo. You use navigation to select which the viewer uses.
    Does that give you a start?
    Where did that last Jeff post come from? It wasn't there a moment ago!
    Apr 18, 2013 4:28 PM   in reply to Stan Jones
    I post in stealth mode...
    Apr 18, 2013 5:56 PM   in reply to IslayMalt
    Do A/V amps and Blu Ray players that can't read DTS-MA 5.1 tracks automatically down-mix them to stereo and I shouldn't be worried about this at all?
    It is preferable to offer both options. But it is very common for Bluray players/systems to handle 5.1.
    Do I need to import the same clip into Premerie twice, once with a stereo track and once with the 5.1 and then manually "paste" the stereo strip into the timeline above the 5.1 tracks in the Premiere segment?  Or will Encore generate or derive a stereo down-mix from the 5.1 when it preps the file for burning to Blu Ray?
    If you already have the 5.1 file, you export a stereo file from Premiere (or whatever program). In encore, you have a timeline with the video file, and on the first audio track you add either audio file. Then you add a second audio track and add the other audio file to it.
    See "Navigation for audio and subtitle tracks":
    http://help.adobe.com/en_US/encore/cs/using/WSbaf9cd7d26a2eabfe8074010 38582db29-7e8ca.html
    Apr 18, 2013 7:59 PM   in reply to IslayMalt
    Good luck!
    May 2, 2013 2:57 AM   in reply to Jeff Bellune
    Jeff - is Minnetokas Surcode required in order to make a BD play 5.1 properly on a set top BD player ?  Or will PPro encoding to dolby digital ( adobe)  be sufficient for En ?  ( all CS6)
    May 2, 2013 3:32 AM   in reply to idar lettrem
    You can't create a DD5.1 audio stream with Pr unless you use a third-party solution like the Surcode plug-in.  (I don't know of any other DD5.1 plug-ins for Pr offhand.)  You could also export a multi-channel WAV file from Pr to use in an external encoder.  The important thing is that the 5.1 audio stream is kept separate and imported into En as an asset.  It must show up in the project panel in En as "Don't Transcode", which will indicate that En will pass through the 5.1 audio.  If En re-transcodes it, then all you'll get is stereo DD.
    Jeff
    May 2, 2013 6:24 AM   in reply to Jeff Bellune
    OK. Then it's minnetoka next, BUT I have two more trials to go and I have some issues to  resolve first .  I'm in a situation where I want to backup a number of my music BD's. Aiseesoft does an exellent job on ripping these, and transcodes to ( takes care of)  ac3 audio format  (mp4 container). I've tried a number of approaches - mpeg2_ts, h264.ac3 etc. (http://forums.creativecow.net/thread/145/870940)
    How should I define the audio track setup subsequently in PPro  - define a single master 5.1 , define 6 separate A-channels , or define 6 separate + one 5.1 ? From a number of tutorials I've seen this should  be quite an easy task, but I can't get  it to work properly. And I've come to realize that En does exactly what it is told to - but so far stereo, strero and nothing but stereo outputs. And thats not En's fault as the sound file shows up as "dont transcode" - but my bad somewhere else ...
    any more help here?
    May 10, 2013 10:02 AM   in reply to IslayMalt
    Please Help,
    Many Thanks,
    IslayMalt
    Hi Caol Ila
    Actually, DTS-HD MAS is a mandatory codec that is supported by all BluRay players. The problem is that the lossless component is not mandatory - only the core audio is - so although the DTS-HD MAS light will come on, you may be hearing the lossy core stream. The same rule applies to Dolby True HD as well, and again (I know Encore does not support this codec) it is quite possible early Profile 1 players will only putput the core AC3 stream and again not the lossless one. With Profile 1.1 & 2 players, the odds of it not supporting the full fat DTS-HD MAS stream are vanishingly small.
    You should also set the downmix to stereo coefficients in the DTS-HD MAS encoder.
    That said, it is a good idea to add a separate stereo stream, as a downmix is a compromise.
    Way to do this?
    Firstly work out what the domninant stream type is - 5.1 or stereo. If you have mainly stereo but with the occasional 5.1, set stream 1 to be the stereo one.
    Add the DTS-HD MAS stream as number 2 - you will not be able to proof this or preview it though as support is passthrough only.
    From your description, I would do one of 2 things:
    First Choice - separate DTS-HD MAS 5.1 & LPCM stereo streams.
    Second - Just DTS-HDS MAS with a downmix for stereo.
    Always, but always add a downmix to the 5.1 stream as you can be certain some silly sod will try to play it on a stereo system.
