I have been asked by our developers to publish a RH project to a secure Web server using SFTP. The RH publishing dialog box only shows the option of FTP, is there a way it can support SFTP?
Chris
Not natively as you have found. On the basis this is the first time I have seen that question posted on any authoring forum, I doubt it would rate as a high priority feature change.
A polite version of "you want it, you do it" seems to be the answer to your developers. I say that as whilst you could purchase a suitable tool, why spend the money when they likely already have something.
Here's a free tool if it helps. I have no knowledge of it.
http://winscp.net/eng/index.php
Thanks Peter. Just as I thought! I will use the "you want it, you do it" approach and thanks for the link, I will check that one out.
Chris
