grandascreativos
Two animations on the same page html5 - toolkit for createjs
Apr 18, 2013 11:33 PM
Tags: #toolkit_for_createjs
Hello, I'm trying to do two animations on the same page and I can not, I'm a designer and I am looking for a guide to resolve this.
thanks.
This is my code:
<!DOCTYPE html>
<html>
<head>
<meta charset="UTF-8">
<title>CreateJS export from hola</title>
<script src="easeljs-0.6.0.min.js"></script>
<script src="tweenjs-0.4.0.min.js"></script>
<script src="movieclip-0.6.0.min.js"></script>
<script src="hola.js"></script>
<script src="cloud gc.js"></script>
<script>
var canvas, stage, exportRoot;
function init() {
          canvas = document.getElementById("canvas");
          exportRoot = new lib.hola();
          stage = new createjs.Stage(canvas);
          stage.addChild(exportRoot);
          stage.update();
          createjs.Ticker.setFPS(30);
          createjs.Ticker.addEventListener("tick", stage);
function init() {
          canvas = document.getElementById("cloud");
          exportRoot = new lib.cloudgc();
          stage = new createjs.Stage(cloud);
          stage.update();
          createjs.Ticker.setFPS(10);
</script>
</head>
<body onload="init();" style="background-color:#D4D4D4">
          <canvas id="canvas" width="550" height="400" style="background-color:#ffffff"></canvas>
    <canvas id="cloud" width="550" height="400" style="background-color:#ffffff"></canvas>
</body>
</html>
    Apr 19, 2013 4:33 AM   in reply to grandascreativos
    You have two functions with the same name: init(). Only the first one will ever be called. You can fix this in two ways. You can change the name of the second function to something else, like "init2()". And then in the body tag add that function's name; <body onload="init(); init2();" style="background-color:#D4D4D4">
    A second way is to cut all of the content from the second init function and paste it into the first init function:
    function init() {
              stage.update();
              stage.update();
    Aug 31, 2013 7:33 PM   in reply to grandascreativos
    It seems like I am dealing with the same issue.  But simply adding the init2() isn't working...
    Here is my code.
    <!DOCTYPE html>
    <html>
    <head>
    <title>CreateJS export from Boy_small</title>
    <script src="http://code.createjs.com/easeljs-0.6.0.min.js"></script>
    <script src="http://code.createjs.com/tweenjs-0.4.0.min.js"></script>
    <script src="http://code.createjs.com/movieclip-0.6.0.min.js"></script>
    <script src="http://code.createjs.com/preloadjs-0.3.0.min.js"></script>
    <script src="http://code.createjs.com/soundjs-0.4.0.min.js"></script>
    <script src="Boy_small.js"></script>
    <script src="SUN_MOVING.js"></script>
    <script>
    function init() {
              canvas = document.getElementById("sun");
              images = images||{};
              var manifest = [
                        {src:"images/Sun20000021.png", id:"Sun20000021"}
              var loader = new createjs.LoadQueue(false);
              loader.addEventListener("fileload", handleFileLoad);
              loader.addEventListener("complete", handleComplete);
              loader.loadManifest(manifest);
    function handleFileLoad(evt) {
              if (evt.item.type == "image") { images[evt.item.id] = evt.result; }
    function handleComplete() {
              exportRoot = new lib.SUN_MOVING();
              stage = new createjs.Stage(sun);
              stage.update();
              createjs.Ticker.setFPS(24);
    function init2() {
              var manifest = [
                        {src:"sounds/RelaxationSoothingSoundsofNaturewav.mp3", id:"RelaxationSoothingSoundsofNaturewav"}
              loader.installPlugin(createjs.Sound);
              exportRoot = new lib.Boy_small();
              stage.update();
    function playSound(id, loop) {
              createjs.Sound.play(id, createjs.Sound.INTERRUPT_EARLY, 0, 0, loop);
    </script>
    </head>
    <body onload="init(), init2();" style="background-color:#D4D4D4">
              <canvas id="canvas" width="224" height="245" style="background-color:#FFFFFF"></canvas>
    <canvas id="sun" width="550" height="400" style="background-color:#FFFFFF"></canvas>
    </body>
    </html>
    Any and all help would be greatly appreciated!!!
    Sep 1, 2013 7:32 AM   in reply to Will at RR
    You have two "handleFileLoad()" and two "handleComplete()" functions. Try renaming the second set and changing the names in the eventListeners that call them.
    Sep 1, 2013 9:12 AM   in reply to Rob Dillon
    Thank you man! That did it.  Thank you for getting me back on track!
    Sep 5, 2013 9:37 AM   in reply to Will at RR
    Hey... You helped me before. Which I thank you for!  I am now trying to load a different js and I'm running into issues.  My sun canvas will only partially load.  It won't load it's image files....
    This is my code
    <script src="Orange_shorts_wc.js"></script>
    <script>
    function init() {
              var manifest = [
              loader.addEventListener("fileload", handleFileLoad2);
              loader.addEventListener("complete", handleComplete2);
    function handleFileLoad2(evt) {
    function handleComplete2() {
              stage.update();
    function init2() {
              createjs.MotionGuidePlugin.install();
              exportRoot2 = new lib.Orange_shorts_wc();
              stage.addChild(exportRoot2);
              stage.update();
    </script>
    Any help much appreciated.
    Sep 6, 2013 9:36 AM   in reply to Will at RR
    Here are comments on the code that you showed. There may be other problems.
    // these five lines are calling some createjs libraries that will be used by your code
    // these two lines are calling two javascript libraries that were written by Flash
    // these two files should be in the same folder as the document that contains the code below
    <script>
    // this line declares some global variables, you probably need to add exportRoot2
