jaynov17
Links in RoboHelp Linked Documents
Apr 19, 2013 2:14 AM
When linking word document the links in the document file (which are internal to the document) are not updated in RoboHrlp10. I have to re-link the links again before output generation. Does not RoboHelp retain links in the document?
    Apr 25, 2013 3:16 AM   in reply to jaynov17
    Have you checked the options when you link? There is an option for Convert Cross References to Hyperlinks. I am wondering if that is behind your problem.
    @petergrainge
    Apr 25, 2013 4:43 AM   in reply to jaynov17
    Yes but if you really mean Linked documents in Rh, every time you update, those links are going to need fixing again. Are you Linking or Importing?
    @petergrainge
    Apr 25, 2013 6:55 AM   in reply to jaynov17
    Right click the document in Project Manager and select Properties. You should then see an Edit button that takes you to the dialog where you mapped your styles. Click Other and you will see the option.
    There is a page on Linking on my site.
    @petergrainge
