BMurr2
InDesign to PDF to Word
Apr 19, 2013 8:27 AM
Tags: #acrobat #word #pdf #indesign
I am trying to bring Indesing docs to PDF and through Acrobat I am saving them as Word docs. When i open them in Word they come out with some problems. The images have missing pieces adn they opacities are off. They deffault to 100%. I want to know if there is a way to prevent this. Are there anyhtings I can do in indesign or how the PDF is Saved? Or will i jus thave to replace the images in Word?
    Apr 19, 2013 8:33 AM   in reply to BMurr2
    Were you actually expecting this to be perfect? If so, I suggest your
    remove that thought from your head.
    That said, what settings did you use when exporting the PDF?
    Bob
    Apr 19, 2013 9:28 AM   in reply to BMurr2
    I need more than default. It sounds like a flattened PDF my be at fault. What is the Acrobat compatibility?
    Bob
    Apr 19, 2013 10:09 AM   in reply to BMurr2
    And this was an export, right? You didn't print to PDF or distill?
    Can you post screenshots of the problem?
    Bob
    BMurr2 <mailto:forums_noreply@adobe.com>
    Friday, April 19, 2013 1:06 PM
          Re: InDesign to PDF to Word
    created by BMurr2 <http://forums.adobe.com/people/BMurr2> in
    /InDesign/ - View the full discussion
    <http://forums.adobe.com/message/5251206#5251206
    Apr 19, 2013 10:20 AM   in reply to BMurr2
    It would be a lot easier with the PDF.
    Some ID PDFs don't translate out of Acrobat well. Fact of life. I use the  Export as Word (DOCX) command. Acrobat XI does better than previous versions in my experience. But some images simply don't do well once in Word.
    Take care, Mike
    Apr 19, 2013 12:25 PM   in reply to BMurr2
    Sorry, no, I haven't paid a whole lot of attention. Some transparency works with some images, some don't do well. Heck, AI doesn't always like ID PDFs for that matter.
    And I have only did this X number of times as it simply isn't a good workflow. I have only tried it after the fact as a shortcut to building a Word template. Usually I know ahead of time and so export from PS or AI with that in mind (one set for ID, one for Word specifically) and favor exporting images and or build-ups of images as single PNGs when destined for Word.
    I haven't see the dropout that you are experiencing. What PDF flavors are you using?
    Mike
    Apr 19, 2013 12:49 PM   in reply to BMurr2
    Hmmm...when I see the way these have broken up and lost their transparency, combined with the types of basic shapes involved, I  suspect these are all native-drawn InDesign items, as opposed to placed graphics or images. It just looks like their object-level properties are being lost/flattened/misinterpreted, which I wouldn't expect to happen with self-contained, linked files.
    While I don't relate to the logic of your workflow, (nor do I know whether my presumptions are true), if this was mine, I'd try giving those items a layer of parse-protection by "double-baking" them. Export pages with these problematic items to a flattened PDF. Then, assuming the problematic items look correct in the resulting PDF, replace the original problematic items with placed-pdf versions before exporting to the whole thing to PDF to Word. I have no ideal whether it will work, but I'd try it.
    Apr 19, 2013 2:17 PM   in reply to BMurr2
    @BMurr2
    Flavors = versions, types
    Sorry. Mike
