Frustrated Eddie
Scroll bar not working in swf when live on web
Apr 19, 2013 9:31 AM
Tags: #help #not #flash #script #working #scroll #component #bar #scrollbar #actions #please #frustrated #thanks
Hi. I've created a flash document for use on the web that incorporates a default scroll bar component in a text field. The scroll bar works fine when I preview it in flash. Also when it's published it works. When I open the files that I place on the server it also works. For some reason when I go to the URL to see it live the SCROLL BAR SLIDER IS GONE (just the gray shape is there) you can still navigate the text with the scroll wheel on the mouse but the component does not display/function correctly in the swf. Any idea why this is happening??!?!?!?!? I tried rearranging my code in actionscript bringing the external text loading code (that field is loading an external html file) to the top but that didnt help. any ideas? I'm at my wits end!
  • kglad
    Jul 21, 2002
    Apr 19, 2013 10:05 AM   in reply to Frustrated Eddie
    if the text that's assigned to your textfield is loaded, that could cause the problem.  you may need to assign the scrollbar to the textfield after text is assigned.
  • kglad
    Jul 21, 2002
    Apr 23, 2013 9:30 AM   in reply to Frustrated Eddie
    how is text assigned to the textfield?
  • kglad
    Jul 21, 2002
    Apr 23, 2013 12:49 PM   in reply to Frustrated Eddie
    and here's where you should be assigning (or refreshing) your scrollbar:
    var textLoader:URLLoader = new URLLoader();
    var textReq:URLRequest = new URLRequest("scc_dw.html");
    function textLoaded(event:Event):void
         scc_txt.htmlText = textLoader.data;
    // assign or refresh scrollbar
    textLoader.load(textReq);
    textLoader.addEventListener(Event.COMPLETE, textLoaded);
