InDesign CS6 crash when setting paragraph styles
Apr 19, 2013 9:27 AM
This occurs most frequently when I confirm changes to the "Span Columns" setting in the paragraph style configuration menu.
My applications are all up-to-date.
Please advise,
Ben
Computer spec:
Win7 64 | AMD FX6100 | 16Gb RAM | GTX-480
    Apr 19, 2013 9:33 AM   in reply to Benjamin Goldstein
    Might be a font problem, but that's less llikely on Windows than it is on a Mac, so start with trashing the prefs. see Replace Your Preferences
    Apr 19, 2013 10:10 AM   in reply to Benjamin Goldstein
    You say you're up to date, but let's verify you are running version 8.0.1.
    Is there anything in event viewer?
    Span/split columns can be problematic. I think, maybe, I remember a bug that was related to a specific number of columns in the frame. Do all the frames have a particular column count?
    Apr 19, 2013 10:18 AM   in reply to Peter Spier
    I've found that making changes to Span Columns is problematic in long documents - if changes in the paragraph style cause reflow, especially overset text at the end of a long doc, it's as if it's too much for ID to handle. One potential workaround is:
    1) Copy a small bit of text set in the problem style to a fresh document
    2) Make the changes you want
    3) Save & close the new doc
    4) Import the style from that new doc from no. 3 above into your long doc
    It works, sometimes.
    (What works better is not using Span/Split columns - it'd be a great tool if it was reliable, but it's simply not reliable.)
    Apr 19, 2013 11:04 AM   in reply to Benjamin Goldstein
    If I remember a span/split problem, it wasn't associated with two columns, not that it makes any difference.
