Encore Project Settings and Encoded file is less in Encore than on my Drive.
Apr 19, 2013 3:23 PM
Before Encoding my Premiere Pro timeline in Media Encoder, I had set up my all my menus and all my assets in Encore CS 5.1. After I had done all that, I pressed the "Build button and it said I had around 23 GB left (I am making a Blu-Ray DVD)
So I went back to Premiere Pro CS 5.5 and Encoded my Project through Media Encoder. I set it it H.264 Blu-Ray, PCM Audio, Target Bit Rate was 18.5 and Max Bit Rate was 20. The estimated file size said it was going to be around 23 GB. This was perfect.
So I encoded it and when it was done, on the Hard Drive, it was 23 GB, just like to was supposed to be.
I then imported it into my Encore project and put it on the timeline. I then looked at the Build tab to see how many GB I had left on the Disc. I wanted a little room.
It said I am only using just over 20 GB and have a little over 4 GB left to use..
Why would this happen? I now have more free space.
In Encore, I wento to File ------ Project Settings ------ Default Transcode settings ---- and that was set at:
Max Audio/Video
Codec MPEG 2
Bit Rate = 15 MBPS.
The Audio was on Dolby.
There was a drop down list, in the Bit Rate category, that I could have chosen to use 20 or 25. I left it at 15 for now.
If I go back and choose 20 or 25 would that make the encoding of my whole project (Menus and h.264 Blu-Ray) a little better quality than it is now? Will it increase the size of Encoded project so when I hit the Build tab again it will show I have less space available to use? I want to make the project  as good as it can get without going over the 25 GB limit.
One other thing.
Wih my final project on the Encore Timeline, when I have the Sequence active, on the Project tab in Encore it reads: 19.1 GB Encoded (Audio and Video). the final encode is 23 GB. Why is it going down to 19?
The video looks good and I could burn it to a Blu-Ray now and it would look great. I just want to know if there is some way to make it a little better inside Encore without having to Encode my whole project at a higher Bit Rate knowing that It will be a little less when I bring it into Encore.
Thanks in advance
Premiere Pro CS 5.5
Media Encoder 5.5
Encore 5.1
    Apr 19, 2013 4:22 PM   in reply to EdwurdAdam
    Many issues in this; one problem is understanding file sizes and Encore's handling of project panel sizes and build panel sizes.
    See post 7 here:
    http://forums.adobe.com/message/4838089#4838089
    Regarding bitrate calculators and a shorthand method mentioned by Jeff Pulera, see his post 2 in that same thread. I see that it was regarding DVD; I wonder if someone has a shorthand like that for Bluray?
