Flex PrintDataGrid has missing rows
Apr 21, 2013 2:25 PM
Tags: #printdatagrid
I've seen this issue posted before. I've tried several of the work arounds and still i get partial or missing rows.I've copy the example from this site:
my PrintDataGrid Attributes are: sizeToPage="true"  varableRowHeight="true" wordWrap='true'.  even when varableRowHeight and wordWrap are set to false the same problem occurs. here is my code:
private function printOrders():void
                var printJob:FlexPrintJob = new FlexPrintJob();
                // Start the print job.
                if (printJob.start()) {
                    // Create a FormPrintView control
                    // as a child of the application.
                    var thePrintView:AllOrdersPrintView = new AllOrdersPrintView();
                    addElement(thePrintView);
                    // Set the print view properties.
                    thePrintView.width=printJob.pageWidth;
                    thePrintView.height=printJob.pageHeight;
                    // Set the data provider of the FormPrintView
                    // component's DataGrid to be the data provider of
                    // the displayed DataGrid.
                    var arrList:ArrayList = new ArrayList();
                    for each (var x:XML in _orderList){
                        var obj:Object = new Object();
                        obj.idOrder = x.@idOrder;
                        obj.delegate = delegateData(x);
                        obj.grade = x.@grade;
                        obj.purchaser = purchaserData(x);
                        obj.cover = coverTypeData(x);
                        obj.quantity = quantityData(x);
                        obj.date = dateConverter.format(String(XML(x).@orderTime));
                        arrList.addItem(obj);
                    thePrintView.myDataGrid.dataProvider = arrList;
                    // Create a single-page image.
                    thePrintView.showPage("single");
                    // If the print image's DataGrid can hold all the
                    // data provider's rows, add the page to the print job.
                    if(!thePrintView.myDataGrid.validNextPage)
                        printJob.addObject(thePrintView);
                        // Otherwise, the job requires multiple pages.
                    else
                        // Create the first page and add it to the print job.
                        thePrintView.showPage("first");
                        thePrintView.pageNumber++;
                        // Loop through the following code
                        // until all pages are queued.
                        while(true)
                            // Move the next page of data to the top of
                            // the PrintDataGrid.
                            thePrintView.myDataGrid.nextPage();
                            // Try creating a last page.
                            thePrintView.showPage("last");
                            // If the page holds the remaining data, or if
                            // the last page was completely filled by the last
                            // grid data, queue it for printing.
                            // Test if there is data for another
                            // PrintDataGrid page.
                                // This is the last page;
                                // queue it and exit the print loop.
                                break;
                            else
                                // This is not the last page. Queue a middle page.
                                thePrintView.showPage("middle");
                    // All pages are queued; remove the FormPrintView
                    // control to free memory.
                    removeElement(thePrintView);
                // Send the job to the printer.
                printJob.send();
the grid
<?xml version="1.0"?>
<!-- printing\myComponents\FormPrintView.mxml -->
<mx:VBox xmlns:fx="http://ns.adobe.com/mxml/2009"
         xmlns:mx="library://ns.adobe.com/flex/mx"
         xmlns:MyComp="myComponents.*"
         backgroundColor="#FFFFFF"
         paddingRight="50" paddingTop="50" paddingBottom="50" paddingLeft="50" xmlns:components="com.treering.components.*">
    <fx:Script>
        <![CDATA[
            import mx.core.*
                // Declare and initialize the variables used in the component.
                // The application sets the actual prodTotal value.
            public var pageNumber2:Number = 1;
            [Bindable]
            public var pageNumber:Number = 1;
            // Control the page contents by selectively hiding the header and
            // footer based on the page type.
            public function showPage(pageType:String):void {
                if(pageType == "middle" || pageType == "last") {
                    // The header won't be used again; hide it.
                    header.includeInLayout=false;
                    header.visible = false;
                //Update the DataGrid layout to reflect the results.
                validateNow();
    </fx:Script>
    <!-- The template for the printed page,
    with the contents for all pages. -->
    <mx:VBox width="100%"  horizontalAlign="left">
        <mx:Label text="Page {pageNumber}"/>
    </mx:VBox>
    <components:AllOrdersHeader id="header"/>
    <!-- The sizeToPage property is true by default, so the last
    page has only as many grid rows as are needed for the data. -->
    <mx:PrintDataGrid id="myDataGrid" width="100%"   variableRowHeight="true" wordWrap="true"  >
        <!-- Specify the columns to ensure that their order is correct. -->
        <mx:columns>
            <mx:DataGridColumn dataField="idOrder" width='60' headerText="Order #"  />
            <mx:DataGridColumn dataField="delegate" headerText="Purchasee" />
            <mx:DataGridColumn dataField="grade" width="75" headerText="Grade" />
            <mx:DataGridColumn dataField="purchaser" headerText="Purchaser" />
            <mx:DataGridColumn dataField="cover" width="40" headerText="Cover"/>
            <mx:DataGridColumn dataField="quantity" width="60" headerText="Quantity"/>
            <mx:DataGridColumn dataField="date" headerText="Date"/>
        </mx:columns>
    </mx:PrintDataGrid>
</mx:VBox>
thanks
Larry Ackner
    Apr 21, 2013 11:30 PM   in reply to lmack710
    I think if you change the DG’s height from page to page you may need to adjust verticalscrollposition
    Apr 22, 2013 8:28 PM   in reply to lmack710
    PrintDataGrid should have a verticalScrollPosition property that controls what the topmost row is.
