berylliumbanana
Insert keyframe inserts a blank keyframe instead
Apr 22, 2013 9:01 AM
I've only been using Adobe Flash CS6 for two months, so it's all fairly new to me.
However, starting yesterday I encountered a very frustrating problem: when I go to insert a keyframe (F6) it inserts a blank keyframe instead. I am unable to insert a non-blank keyframe, and have to manually copy the previous frame over. The same thing happens even when I don't use the hot key.
  • kglad
    Jul 21, 2002
    Apr 22, 2013 9:54 AM   in reply to berylliumbanana
    right click a timeline frame>click insert keyframe.
    any problem?
    if yes, are you using a mac?
  • kglad
    Jul 21, 2002
    Apr 22, 2013 1:07 PM   in reply to berylliumbanana
    there are other ways to insert a keyframe.
    regardless, you could try resetting your preferences.  from suhas yogin:
    Hold down Shift+Ctrl+Alt (Win) or Shift+Command+Option (Mac) prior  to launching Flash Professional. If this interferes with an OS dialog, hold  this keyboard combination immediately after launching Flash until you  see the prompt to reset preferences
  • kglad
    Jul 21, 2002
    Apr 23, 2013 7:21 AM   in reply to berylliumbanana
    did you continue to hold those down during flash startup?
  • kglad
    Jul 21, 2002
    Apr 23, 2013 7:46 AM   in reply to berylliumbanana
    then uninstall (and check the box to remove preferences) and, reinstall.
  • kglad
    Jul 21, 2002
    Apr 23, 2013 9:21 PM   in reply to berylliumbanana
    you're welcome.
    sorry, you weren't able to reset using shift-ctrl+alt.  that's a much more convenient way to reset preferences.
