InDesign CS5.5 Documents Not Working with Drive 4.2
Apr 23, 2013 10:19 AM
I am using CS 6 and Adobe Drive 4.2 (4.2.0.110) on Windows 7 with the CMIS adapter against an Alfresco v4.0.0 repository.  When I double-click on an InDesign CS6 file in windows explorer, it opens in InDesign.  I see the "up-to-date' status icon in the lower left in InDesign.  I can edit the document and successfully check it back into Alfresco.  When I try the same test case using a CS 5.5-created document, the "up-to-date" icon does not appear and I can't version the document in Alfresco.
These two documents reside in the same folder and were created by the same user in Alfresco.  They are both simple documents that only contain text boxes; no external links.
The AD4ServiceManager_java.log file contains the following and was deleted before trying the CS5.5 test case:
2013/04/23 11:15:29,471 [ConnectionHandler-Adobe Drive.exe-3732] INFO  GetConnectorInfoHandler - -->In()
2013/04/23 11:15:29,545 [ConnectionHandler-Adobe Drive.exe-3732] DEBUG IconHelper - Configuring Win volume icon.
2013/04/23 11:15:29,548 [ConnectionHandler-Adobe Drive.exe-3732] INFO  GetConnectorInfoHandler - -->Out()
2013/04/23 11:16:24,222 [IFSConnection-1] ERROR GetAssetsHandler - asset not found: /User Homes/mjackson/irml.dll
2013/04/23 11:16:24,449 [IFSConnection-1] ERROR GetAssetsHandler - asset not found: /User Homes/mjackson/adobe_licutil.exe
2013/04/23 11:16:29,224 [IFSConnection-1] ERROR GetAssetsHandler - asset not found: /User Homes/mjackson/tes8E12.tmp
2013/04/23 11:16:29,245 [IFSConnection-1] ERROR GetAssetsHandler - asset not found: /User Homes/mjackson/tes8E12.tmp
2013/04/23 11:16:29,265 [IFSConnection-1] ERROR GetAssetsHandler - asset not found: /User Homes/mjackson/tes8E12.tmp
2013/04/23 11:16:29,992 [JobHandler-2] ERROR GetAssetById - Caught exception
com.adobe.drive.data.model.DriveException: com.adobe.drive.data.model.asset.ModelObjectNotFoundException: Cannot find class com.adobe.drive.data.internal.model.Asset with id='70'
    at com.adobe.drive.data.model.asset.DeprecatedAssetFactory.findAssetById (DeprecatedAssetFactory.java:42)
    at com.adobe.drive.internal.data.manager.DataManager.getCachedAsset(Data Manager.java:1786)
    at com.adobe.drive.internal.biz.versioncue.service.call.GetAssetById.exe cuteItem(GetAssetById.java:59)
    at com.adobe.drive.internal.biz.versioncue.service.call.GetAssetById.exe cuteItem(GetAssetById.java:1)
    at com.adobe.drive.internal.biz.versioncue.service.call.VersionCueCall$1 .run(VersionCueCall.java:125)
    at com.adobe.drive.internal.biz.versioncue.service.call.VersionCueCall$1 .run(VersionCueCall.java:1)
    at com.adobe.drive.data.internal.persistence.PersistenceRunner.run(Persi stenceRunner.java:119)
    at com.adobe.drive.internal.biz.versioncue.service.call.VersionCueCall.e xecute(VersionCueCall.java:137)
    at com.adobe.drive.internal.biz.versioncue.service.VersionCueService.get Asset(VersionCueService.java:234)
    at com.adobe.drive.ncomm.versioncue.GetAssetById.handle(GetAssetById.jav a:54)
    at com.adobe.drive.ncomm.versioncue.VersionCueRequestHandler$1.run(Versi onCueRequestHandler.java:185)
    at com.adobe.drive.core.internal.jobs.JobHandler$JobWrapper.run(JobHandl er.java:270)
    at com.adobe.drive.core.internal.jobs.JobHandler$JobWrapper.run(JobHandl er.java:286)
    at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
    at java.lang.Thread.run(Unknown Source)
Caused by: com.adobe.drive.data.model.asset.ModelObjectNotFoundException: Cannot find class com.adobe.drive.data.internal.model.Asset with id='70'
    at com.adobe.drive.data.persistence.factories.AssetFactory.findAssetById (AssetFactory.java:244)
    at com.adobe.drive.data.model.asset.AssetFactory.findAssetById(AssetFact ory.java:69)
    at com.adobe.drive.data.model.asset.DeprecatedAssetFactory.findAssetById (DeprecatedAssetFactory.java:38)
    ... 15 more
2013/04/23 11:16:31,820 [IFSConnection-1] ERROR GetAssetsHandler - asset not found: /User Homes/mjackson/Document fonts
2013/04/23 11:16:31,839 [IFSConnection-1] ERROR GetAssetsHandler - asset not found: /User Homes/mjackson/Document fonts.lnk
2013/04/23 11:16:31,859 [IFSConnection-1] ERROR GetAssetsHandler - asset not found: /User Homes/mjackson/Document fonts.URL
Rich
