jfairley2
How do I import a file as a subclip?
Apr 23, 2013 11:41 AM
Tags: #scripting
In my panel, I have representations of clips and subclips from an external system. So far I can only see how to import an entire video into Premiere. Is it possible to import a subclip?
To import an entire video, I currently do the following:
Premiere.app.project.importFiles(["/path/to/file.mov"]);
I see the importFiles() takes a generic Object. Is there a struct that I can use for defining mark-in/mark-out points for this imported video?
    Apr 24, 2013 1:12 PM   in reply to jfairley2
    No, but...
    If the file contains XMP metadata defining sub-clips (created in Prelude, for instance), those will be available in PPro.
    You can also create a sequence in FCP XML, and import that.
    [Feel free to write me directly for panel development help.]
    May 16, 2013 11:31 AM   in reply to jfairley2
    Did creating a sequence, and importing that, help?
    May 19, 2013 6:25 AM   in reply to jfairley2
    For the XML structure, see Apple's spec for guidance, but yes, using PPro-generated FCP XML as a template is a good approach.
    To the extent that FCPX supports FCP7 XML (I don't know what that extent is), yes, it should import correctly.
