Illustrator Raise Text
Apr 23, 2013 1:04 PM
Tags: #cs4 #illustrator #photoshop #cs5 #help #font #color #size #pdf #adobe #effects #text #mac #export #crash #bug #creative #path #printing #tool #type #stroke #cs6 #objects #cloud
I was wondering if i could get text which is simply the letters MLA raised of the page like in the below image. Polyester_brushed_lg.jpg
    Apr 23, 2013 1:18 PM   in reply to AJMDesigns
    Are you asking how or asking someone to do it for you?
    Apr 23, 2013 1:37 PM   in reply to AJMDesigns
    You can 3D > Extrude Text
    But you often run into problem liek miter limit on the M which I could nto fix This is better done in Phothsop using inner bevel. You can also better achieve a chrome and brushed metal effect if needed in Photoshop. Alien Skion has a plug in for Photohsop which gets you even better options.
    Also for Illustrator  http://www.shinycore.com/products/pathstyler/
    Apr 23, 2013 1:39 PM   in reply to Mike Gondek
    Its not that difficult in AI.. no 3D needed.
    Apr 23, 2013 3:58 PM   in reply to AJMDesigns
    You would do better to draw it by hand like Scott is showing you.
    It’s a fairly símple job although it may take a minute or two.
    No automatic extruding or embossing will give you a satisfactory result.
    As Mike points out, Photoshop’s Inner Bevel is all right as far as it goes but a hand drawn job will give you even better results.
    Apr 24, 2013 1:57 AM   in reply to AJMDesigns
    Pen tool (probably followed by Live Paint and gradients).
    You will notice that Scott did his sketch in a hurry and that some lines are not parallel that should be.
    Start off with the lettering straight, use ruler guides to ensure consistency between letters and use constrain (Shift) on the pen tool for vertical and horizontal lines.
    Apr 24, 2013 5:39 AM   in reply to Steve Fairbairn
    Yup, just the pen tool. And yup I did it fast to demonstrate and merely manually traced the image posted above. But if I were really creating it for a project I'd ensure all paths are parallel where they should be as well as all character stroke widths were proportionatly correct.
    Actually I'd probably create the character flat without any perspective, then distort once it was complete.
